dumb question
Moyerboy
Kittanning, PA
IDK New here its a 03
ok i feel really dumb asking this question but how do you check the trans fluid on a 03 tdi auto? I have looked and searched and finally gave up so I am coming here.
dan kerkstra
ardmore ok 73401
2009 tdi Jetta 2002 jetta 5spd 2004 Jetta 5spd
I understand there are two plugs together under your trans the inside one is the full line, you remove this plug and put vw trans flud in until it begans to drain out then its full put plug back in, your good to go. Others on here will give you much better info.
dogdots
Kansas City
None
You gotta use VCDS to set the fluid level properly in the 01m trans has to be at a certain temp to get the level correct. Find someone close with VCDS and experience with the 01m (hint hint find a trusted tdi mechanic close to you)
dieselnewbie
Northwest Indiana
2000 Silver Jetta TDI
I had the same question when I first got my car. The 01M auto is supposed to be a lifetime transmission and doesn't have a dipstick or readily accessable fill tube. If you want to check the fluid you need to warm the fluid to a specific temp (hence the need for the Vag Com), then take out the plug to see what hapens. If alot of fluid comes out then there was too much in there, and if nothing comes out then there isn't enough. To add fluid, you need to remove a cover plate and screw in a plug when you're done filling. The Bentley guide does a much better job of explaining this than I do, but I think that that's the jist of it. Personally my trans has been working well all along, but did change the fluid and filter at 200,000 miles just to be safe. Haven't had any issues before or after, but I believe that my experiences with this trans aren't necessarily the norm...
Moyerboy
Kittanning, PA
ok well I do want to change it just to be safe I heard they are a weak tranny but, I didnt buy the car to be a racecar just alittle zip from a tune and great fuel mileage. Ill have to find some one with a vagcom in my area to get the temp and what not o I can attempt to do this. thanks for the helpful words guys
earlthepearl
Morganton, NC
2000 New Beetle 5M, 2004 Passat 6M, 2009 Jetta Sedan (buy back), 2010 Touareg (buy back)
Clutching
Before the wife's former 05 Passat TDI, her current Touareg TDI, and a Eurovan, none of which had problems with the auto trans, I've only owned two other cars that were not manuals. Guess what broke on those vehicles first? :mad: Having owned lots of cars, 13 of which have been VWs, I've never had a manual trans break on me. Hearing rumors of the eventual demise of "three pedal" cars saddens me.:(
