Hello,
Has anyone tried DSLA150P261 nozzles?
Firad markings are ASLA150P261
They are 0.240mm
They are from ROVER MAESTRO 2,0TD, MONTEGO 2.0 TD, 60kW what are using Perkins Prima engine.
Jeah for 1.9 TDI.
This nozzles are cheap compared to aftermarket nozzles.
This nozzles are mentioned few times before in this forum.
I found answer to my question: HERE
You have to turn injector 90 degrees to get nozzle into correct position, everything else is ok.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
