I'm in the process of changing the trans fluid in my Passat. I followed Blauparts recommendation to leave the engine idling while filling the last 3.5 liters of fluid, but because I filled it by gravity flow it took a while (I put in 6 liters total). When I hooked up the VAG it said the trans temp is at 69 degrees Celsius. As I understand it, to establish the correct level the trans temp needs to be between 35 and 45 Celsius. So my oil was too hot when I filled it, meaning that it's probably not full enough. How do I correct this? I put in about 5.7 liters of fluid, which means that there is probably half a liter or so sitting in the "overflow" part of the transmission. Can I just start the car up again when the transmission is cooled down, warm it up, and then check the level? Is there any point in adding more fluid?
