TDIblues
Well completed the scheduled trans fluid change, followed the factory process step by step. All OEM parts including oil, installed 5.5 liters, fired up the VAG-Com to check the trans oil temp and had 39 C at idle, let it run for 10 min and it climbed to 53 C, 15 min it was at 58 C.
Added 1/2 of the 6th liter that was left over and the temp went up to 60 C???
Added the remaining oil and the temp went up to 62 C???
At this point I removed the fill tool and installed the drain plug, did a test drive and the temp increased to 71 C. Shifted well, no problems noted.
My question is the recommended temp is 35 to 45 C??????? At what start up ?? idle??? when driving??? I never saw anything below the initial 39 C.
I really don't want to destroy the trans but this is starting to get a bit silly changing your trans fluid should not be this difficult.
Any and all comments are welcome!
