360gtracer
Pros/cons of the *NECESSITY* of performing this dealer-recommended service every 40K miles??
Thanks.
Thanks.
Haha, thanks! Your pros/cons are perfect, why didn't I think of that? But seriously, I've kind of viewed it as a revenue stream for the dealer, wondering if the DSG is that fragile (to use a word I've been seeing a lot of here this morning). There certainly don't seem to be any issues with it currently (it was done around 40K/5 or 6 years ago, and the car now has ~86K... '14 Beetle, not a high mileage car by any stretch.)Pros: transmission continues to work as designed.
Cons: it doesn't.
It is not a "dealer recommended" thing, it is a "manufacturer specified" service.
Dealer prices for this are generally higher than they should be, in my opinion. It isn't all that hard to do, really.
And really, if that cost has your George Costanza gland puckering, you probably should not have bought that car. Wait until the DPF goes bad!![]()
If you go buy a trans service kit from any reputable parts place,you can do it yourself. Not only that, you can reuse the kit for future flushes which lowers the cost significantly. I think my kit was $240, that included everything to service the trans, a new drain plug and the little plastic tower that you can replace(that i didnt need to buy)that screws up into the drain hole. Its extremely easy if you have any mechanical aptitude and the worst part is the waiting for the trans to fill back up.Pros/cons of the *NECESSITY* of performing this dealer-recommended service every 40K miles??
Thanks.
the DSG in our vehicles is the DQ250.Pros/cons of the *NECESSITY* of performing this dealer-recommended service every 40K miles??
Thanks.
I just serviced my transmission today it's a good idea to keep the clutch pack lubricated. It's not a big deal to service it. It's drain and fill. With a filter just below the battery bracket. So many online tutorials talk about getting the transmission to a specific temperature and checking the fluid level at exactly that temperature. It's really not that critical. The transmission will operate fine 3/4 quart over or under the optimum level. The fluid level will probably go up or down less than a 1/4 quart whether the transmission is hot or cold. Dealer ship wanted 500 to do the service. I did it in about an hour for $100. I bought the DSG service kit from Pentosin on Amazon. Saved me 400 bucks.Pros/cons of the *NECESSITY* of performing this dealer-recommended service every 40K miles??
Thanks.
Youtubers didn't invent the procedure, VW did.So many online tutorials talk about getting the transmission to a specific temperature and checking the fluid level at exactly that temperature. It's really not that critical. The transmission will operate fine 3/4 quart over or under the optimum level.
this works fine, but it makes the leveling procedure a bit more annoying.You can also just pour the fluid in from the top through the filter housing. Takes about 30min to get it all in as it's very slow to go down but works fine.
sure, and putting your engine oil into the hash mark on the dipstick is just a recommendation. half a qt under it is juuuuust fine!So many online tutorials talk about getting the transmission to a specific temperature and checking the fluid level at exactly that temperature. It's really not that critical. The transmission will operate fine 3/4 quart over or under the optimum level.
sorry, but this is quite literally survivorship bias.On the other hand, the "same quantity in and out" method has been used many times with no problems, done it 3 times myself and transmission seems quite happy. I suspect VW put their bottom fill method in the manual because it's faster and their dealers already have the equipment to do it that way.
