DSG owners with VAG-COM or ScanGauge (Engine load at idle)
Mark@MaloneTuning
Blaine, Washington and Vancouver, British Columbia
'14 GSW TDI, '11 Golf TDI, '97 Golf Variant Syncro 1.9L TDI, '96 Golf 1.9L ASV TDI, '93 Eurovan Westfalia 1.9L TDI, '09 BMW 335d, '17 BMW 328d
What is your engine load ("LOD" on ScanGauge II) in two conditions:
1. Engine idling while transmission is in "N" Neutral
2. Engine idling while transmission is in gear (D or S)
The engine must be fully warmed up. A cold engine may report slightly higher load %. The vehicle must not be moving for #2.
My engine load in N is 17-18% and the engine load idling in D or S is 20%. I do notice that idling in N is smoother. I notice that some MKV DSGs vibrate more than others. I am just curious as to know what other people's load % values look like.
Dick_Larimore
Central Indiana
'05 GL Passat & '05 GLS Passat & '05 Beetle TDI
I just sent my scan gauge in for warranty service (the backlight quit working). I will check out the engine loading as soon as I get it back.
abarns
Killeen, TX
2006 Jetta TDI Pkg 1
My load change is similar, I'll grab specifics later.
Edit: Today it was 22% in N and 24% in D...
Bill- I was curious about that same thing some time ago... the scangauge gph numbers only go to the tenth though, so it was .2 in N and D :)
40X40
Experienced
Kansas City area, MO
2013 Passat SEL Premium
You might want to check fuel usage under the same conditions.
Gallons/hour fuel flow (*.**) would be useful to know.
HTH
Bill
