roni024
I noticed a couple oil spots in my driveway so decided I should take a peek beneath the car. Upon doing so, I could see a light golden colored oily fluid on the lower front and underside of the DSG. I traced the leak to where I suspect it to be coming from, and it seems like it is the cover for the mechatronics unit of the gearbox.
Has anyone had any issues with leaks in that area? My dealer stocks a gasket for around $12, but I don't want to tear into it if I might screw something up. Is there any way to repair the leak with some sort of sealant and keep the mechatronics cover and DSG fluid intact? I was planning to keep the car and get the fix but, seeing how VW is dragging its heals to propose one, I'm leaning heavier and heavier toward the buyback each day that passes...
Thanks.
Thanks.
