hi guys I've been reading up about DSG fluid change and i'm going to do the 'top fill' method... but I got 2 questions
i'll be getting a 14mm allen with 1/2" drive at the back
1. but with the 8mm allen u need to remove the plastic snorkel. will I need an 'socket bit' or will the regular 'L' shaped allen key give enough torque to remove the snorkel? because the 8mm allen bit I found is very short Im not sure if it will be long enough to reach the hex snorkel...
2. when using top fill method from the oil filter housing, what is the maximum Outer diameter for the plastic hose I can fit into that little hole? I've sold my old car so now if the hose I have is too big I can't just go buy one. I need to buy the correct size hose and a funnel first.
thanks
thanks
