DSG "Direct Shift Gearbox" owners data base
wjdell
Central Florida
06 Jetta TDI DSG PKG 1 17" VV Campy White/Beige
Owners of the DSG transmission, in any make or model. We encourage you to register your DSG here. Please add your transmission data in the following form. Add any comments you have to your original post - PLEASE, I am trying to keep this easy for people to scan. You can post information if its relevant to all owners. The data you put in your post should be related to, service, fluid changes, problems, and the resolutions. You can write about you personal experiences with the DSG. Please try to recruit other members to join also. We are some of the first to have F1 technology in our street car transmissions. In the end I believe this transmission will be a winner.
Thank You
WJ Dell
DATE:
Name:
Year:
Make:
Model:
Date of auto production: - " usually month and year " unless you know the day
Engine code: "in your manual"
Transmission Code: - “located in owners manual next to engine code
Date of DSG Production: - “ located on top of trans just below and beside the battery – is visible with flashlight”
Purchased, New or Used:
Miles when purchased:
Current miles: - " update this whenever you chosse "
Area of country: - “ southeast USA, - Melbourne Australia "
Fuel Statistics: - " best/average/worst only please " update this whenever you choose
List dates of any problems and or resolutions. Feel free to list any input you might feel will be helpful with the DSG data base.
If you find interesting articles post the link only
DSG fluid and filter maintenance parts needed
6 liters of DSG fluid part # G052182A2 "could be FUCHS"
1 DSG filter part # 02E305051B (now superceded by last letter C)
1 DSG filter seal part # N91084501
1 Gasket. Part # N 043 809 2.
Suggested tools
14 mm HEX for the drain/fill plug.
8 mm HEX for tube.
VAS 6262.
This tool could be substituted by buying a DSG drain plug and drilling it out. You can then insert a hose nipple into the plug threaded, or you could have it welded. I think the nipple should be the clamp type so the hose can easily be removed for the fill checking. The plug on the bottom of the DSG is 25 mm in diameter and has a 1.5 pitch. I suggest clear hose and many part stores have this. A clean pan to drain the DSG into. I say clean as a inspection of the drained fluid is a good idea as it may show signs of problems.
NOTE
Do not use funnels or hoses that have any other type of oil. Contamination! - The manual is specific about this. Additive contamination may be very harmful to your DSG. Periodic changes are smart and flushing is not reccomended because of contamination from other oil and additives.
Vag-Com is needed to get a running temperature of 35 to 45 C for refill. You could possibly use another means but I am not sure were you would put the test probe.
Its best to do this on a level hard surface. You need not remove the battery to perform the filter change. I think I would prefer to use 4 jack stands or two ramps and 2 jack stands. Keep the vehicle level, that will be critical for proper fill.
1. Remove the engine covers.
2. Disconnect the Mass Air Flow harness
3. Disconnect vent hose and air guide hose
4. Open spring clamp on air guide hose remove from tube
5. Remove filter housing
6. Remove the bottom engine cover
7. Place clean receptacle under DSG
8. Reaching under the battery unscrew filter housing and tilt slightly to empty
9. Remove filter and note is position suction collar is down
10. Remove o-ring seal
11. Install new o-ring seal with coating of fluid
12. Install new filter suction collar down and housing tighten to 15Nm to 20 Nm.
13. Install filter housing
14. Install Mass air Flow harness
15. Install air guide hose
16. Install vacuum hose
17. Connect air guide hose with spring clip
NOTE : There maybe one or two plugs depending on your production date. The rear drain plug and the front is the fill plug. If you have no drain plug than the Fill plug doubles as both. If you have only the one plug than you must remove the snorkel to drain. I suggest you catch all fluid in a clean container and measure !
18. After the fluid is completely drained replace snorkel, 3 Nm.
19. Attach VAS 6262 and pour 5.5 litres of fluid into DSG.
20. Using VAG-COM check DSG temperature.
21. Start engine - do not run engine when trans is empty !!
22. Depress brake select each position for min of 3 seconds. R-N-D-S moving selector to park and DO NOT SHUT OFF THE ENGINE.
23. After the DSG reaches the desired temperature disconnect hose from nipple or adapter coupler on VAS 6262 and allow excess to drain out. When there is only a drip promptly remove adapter and replace the check plug.
NOTE : There will be a cooling pulse every 30 seconds and this is not a indication of overfill. The system is actually idiot proof. It may be easier to cool the fluid before use. CHECK FOR LEAKS and remember clean is the WORD.
Link to the DIY, DSG oil and filter change.
NOTE - Fuch's shows the DSG interval as 60k km or 48 months - I am sure that corrosion may be a issue, and a fluids abilty to resist this is depleted over time.
http://forums.tdiclub.com/showthread.php?p=1639639#post1639639
UPDATE " DMF" DUAL MASS FLYWHEEL
Vw has a new part to supercede the old flywheel. There must have been a problem. The old part is and the new - here is what the parts supplier shows
" Supersession Information Part number 03G105266AP was superseded by part number 03G105266BE."
VOA of VWG052182A2 DSG fluid
Fe Iron --------------------- 0
Al Aluminum --------------0
Cu Copper ---------------- 0
Si Silicone ---------------- 3
Na Sodium --------------- 3
Mo Molybdenum ------- 0
Mn Manganese --------- 0
B Boron ---------------- 118
Sb Antimony ------------- 1
Ca Calcium ------------- 47
P Phosphorus -------- 265
Zn Zinc --------------------- 9
Water Volume ----------- 0.00
Viscosity 100C ---------- 7.50
ISO Code ------------- 21/18/13 - should be better
4 Micron ----------------- 13,068
6 micron ----------------- 1438
10 micron ------------------ 127
14 micron -------------------- 52
21 micron -------------------- 9
38 micron --------------------- 1
70 micron --------------------- 0
100 micron ------------------- 0
TAN ------------------------- 1.00
wjdell
Central Florida
DSG " Direct Shift Gearbox "
Date:08/05/06
Year:2006
Make:VW
Model:Jetta
Date of auto production: 12/05
Engine code: BRM
Transmission Code: HQN
Date of DSG Production: 07/19/05
Purchased, New or Used: New
Miles when purchased: 34
Current miles: 35,000
Area of country: southeast USA
Fuel Statistics: 47.68/42.7/35.3
DSG fault code. When approaching a stop quickly it downshifted abrutly and the trans began flashing. I had to shut the motor off to clear. The next day I found this stored fault code.
Address 02: Auto Trans
Part No SW: 02E 300 042 H HW: 02E 927 770 AE
Component: GSG DSG 070 0913
Coding: 0000020
Shop #: WSC 00066
1 Fault Found:
18227 - Pressure Control Valve 2 (N216): Open or Short to Ground
P1819 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Reset counter: 38
Mileage: 21892 km
Time Indication: 0
The trans never failed and is working well 200 miles after this incident. I cleared the code and all is well. I have run software but all seems normal. It will go to the dealer for evaluation this week. The P1819 in the Bentley is as follows
Replace Direct Shift Gearbox (DSG) mechatronic J743 6 Spd. Direct Shift Automatic Transmission 02E Front Wheel Drive - Repair Group 34.
Went to Stuart Florida VW - and a german gentleman named Helmutt gave it a clean bill of health - So lesson learned do not clear the codes even though I printed and saved to file they may only use 5051 to report to VW. It happened once and it will again I think so then I will leave the code in and let Helmutt decide.
DSG UOA 20,000 miles --- Second UOA 52,000
Fe Iron --------- 26 -- 23
Al Aluminum -- 1---- 1
Cu Copper ---- 8 ---- 6
Si Silicone --- 34 --- 19
Na Sodium ---- 3 ---- 2
Mo Molybdenum - 2 - 1
Mn Manganese - 5 -- 3
B Boron -------- 73 ---- 86
Ca Calcium --- 40 ---- 36
P Phosphorus -- 226 -- 228
Zn Zinc ---------- 22 ----- 14
Viscosity 100C 6.80 ---- 6.40
Ferro Small ---- 19 ---- N/A
Ferro Large ---- 34 ---- N/A
TAN ------------ 0.92 ---- 1.07
PQ Index ----- N/A ------ 10
Vag - Com - 340.00
Bentley Manuals 2 - 160.00
Vas 6262 - 95.00
20k 1st OCI fluid, filter, gaskets with UOA total cost - 167.00 :)
52k 2nd OCI fluid, filter, gaskets with UOA total cost - 145.00
overbite
Eagle Lake, MN
1996 passat
DATE:8-7-2006
Year:2006
Make:vw
Model:jetta
Engine code:
Date of Production: -
Purchased, New or Used:new
Miles when purchased:76
Current miles:~15,000
Area of country: - south central Minnestoa
jocat54
San Antonio Texas
Jetta
Date: 8-8-2006
Year:2006
Make:VW
Model:Jetta
Engine Code:BRM
Transmission Code:-
Date of Production:-
Miles when purchased:15
Current Miles:66000
Area of Country:South Central Texas. San Antonio
ocassionally no throttle response from standing start-seems to happen more after driving for a while. May be my driving habit- wife says it never does it to her.
_______________________________________
2006 Jetta TDI-wifes
2004 Chevy Crew Cab 2500
1993 K1500-Love this truck
tomo366
TDI Lifer, Member #68
Kensington, Maryland USA
2015 Jetta SEL TDI
DATE:08/09/2006
Year:2006
Make:Volkswagen
Model:Jetta TDI
Engine code:BRM
Date of auto production: April 25,2006
Transmission Code: - HXU
Date of Production: - 2/20/06
Purchased, New
Miles when purchased:40
Current miles:3828
Area of country: - Mid Atlantic
I don't know for sure, but I think this car may have had another Transmission put into it.....
It was held at the Plant for nearly a month after the DSG Clip problems arose...
It has a different looking sticker on it.
No problems though.
Vipervnm
Kingwood, NJ
2006 Jetta TDI Package 1
Date: 08/11/06
Year: 2006
Make: VW
Model: Jetta
Date of auto production: 02/06
Engine code: BRM
Miles when purchased: 6
Current miles: 48,000
Area of country: Central NJ, USA
UPDATE: The car is starting to shift unusually rough at an increasing rate. It used to do it on ocassion under WOT, but now it occurs regardless of the RPMs or pedal position. Starting to regret choosing the DSG.
UPDATE 2 (10/17/07, 37,000 miles): Started the car one day and all the weird shifting problems disappeared. It's been nearly 7 months now and the problems haven't resurfaced. Electronic phantoms are so strange.
UPDATE 3 (8/11/08, 48,000 miles): Everything is going well. No codes or problems after fluid change 8,000 miles ago. Good stuff.
UPDATE 4 (12/31/08, 52,000 miles): Out of warranty now. The car keeps getting smoother and smoother. Just got a clean bill of health at 49,998 miles! I wish I could have made at least one warranty claim. Looking forward to several more years and tens of thousands more miles!
bockegg
PA
2009 Jetta Loyalty TDi w/ DSG
Diesel Dog
DATE: 8/12/2006
Year: 2006
Make: Volkswagen
Model: New Beetle
Date of auto production: - 3/2006
Engine code: BEN
Transmission Code: - HXV
Date of DSG Production: - 12/12/2005
Miles when purchased: 210
Current miles: 3,985
Area of country: - Huntingdon, PA
gleep
Idaho
2006 Jetta TDI
DATE: 08/12/2006
Year: 2006
Make: VW
Model: Jetta
Date of auto production: ???
Engine code: BRM
Date of DSG Production: - 04/11/2005
Purchased, New or Used: new
Miles when purchased: 31
Current miles: 13,412
Area of country: - South Central Idaho
gleep
eagle
North Carolina
2013 Jetta
Year: 2006
Make: VW
Model: Jetta
Date of auto production: 6/06
Engine code: BXR
Transmission Code: HXU
Date of DSG Production: 016/09/02/06
Miles when purchased: 8
Current miles: 6,182
Area of country: NC, USA
route66
Chandler, AZ
'06 Jetta pkg1 plat. gray/gray int.
Date:08/19/06
Year:2006
Make:VW
Model:Jetta TDI
Date of auto production: 07/06
Engine code: BRM
Date of DSG Production: tbd
Miles when purchased: 33
Current miles: 4075
Area of country: Arizona, USA
Fuel Statistics: 38-39ish, but I don't baby it and primarily drive in town.
Will update occasionally - This car ROCKS!!!!!!
Still no problems as of this edit/update. Do notice some "roll back" (a few inches, but noticeable) when parking on an incline. Of course I set my brake but have not seen this in other automatic transmissions I have driven.
Kalkaska Mi.
Jetta, 2006, Campanella White, Anthracite Int. DSG, Pkg. 1; New Beetle, 1998, Yellow, black leather Int., 2013 Passat TDI SEL Night blue, grey Int. given back to VW (well, not given... ;) ) 2018 Tiguan; first gasser in years
Date: 08/19/06
Year: 2006
Make: VW
Model: Jetta
Date of Auto Production: 12/2005
Engine Code: BRM
Trans Code: HXU
Date of DSG production: 083/04/08/05 (from tag on trans)
Purchase: New
Miles when purchased: 30
Current Miles: 9000
Locale: Michigan
MPG: Mid 40s
Problems: Hesitation off stops but we're adjusting. No other issues.
BTW, I found the engine and trans codes on a sticker in the spare tire well in the trunk.
Maven
Eastern Iowa
2006.5 Jetta TDI, Black/Black, PKG2
DATE:8/19/06
Year:2006.5
Make:VW
Model:Jetta TDI
Date of auto production: - July 2006
Engine code: BRM
Date of DSG Production: - Haven't crawled in there yet
Purchased, New or Used:New
Miles when purchased:11
Current miles: - 850
Area of country: - Central Midwest (Iowa) USA
Fuel Statistics: - 48.5 Best, 42 AVG, 42 Worst
whitacre
Spring, Texas
2006 TDI New Beetle Pkg 2 Gecko Green!
Date:08/22/06
Year:2006
Make:VW
Model:Beetle
Date of auto production: 01/06
Engine code:
Transmission Code:
Miles when purchased: 284
Current miles: 16,105
Area of country: Houston Texas USA
Fuel Statistics: 47 MPG highest Highway.
tfink
Clayton, OH
2006 1/2 Jetta TDI Package 2
Date:08/25/06
Year:2006 1/2
Make:VW
Model:Jetta
Date of auto production: July '06
Engine code:
Transmission Code:
Current miles: 700
Area of country: Dayton, OH USA
Fuel Statistics: 45 MPG highest Highway.
2004STARWARSTDI
LAKELAND, FL
2004 Platinum Gray GLS Jetta / 2006 Silver Jetta with DSG
DATE: 8/25/2006
Year: 2006
Make: VW
Model: Jetta TDI
Date of auto production: - Jan 2006
Engine code: BRM
Date of DSG Production: 036/23/11/05
Purchased, New or Used: NEW
Miles when purchased: 50
Current miles: - 19000
Area of country: - “ southeast USA, Lakeland, Fl
Fuel Statistics: - " best/average/worst 48.3/41/39
Pelican18TQA4
Philadelphia, PA
'13 Jetta Hybrid
DATE: 08/26/06
Year: 2005
Make: VW
Model: New Beetle
Date of auto production: 12/2004
Engine code: BEW
Transmission Code: HLJ
Date of DSG Production: ??
Miles when purchased: <30
Current miles: 21,XXX
Area of country: southeastern PA
Fuel Statistics: 38/36/31
No problems to report at all, never a hiccup!
JETGUY
Cuyahoga Falls Ohio
2006 Jetta DSG
DATE: 08/26/06
Year: 2006
Make: VW
Model: Jetta
Date of auto production: 02/2006
Engine code: BRM
Miles when purchased: <5
Current miles: 7150
Area of country: North East Ohio
Fuel Statistics: 55.53/38.58/30.61
No problems
kharmin
East-ish St Paul, MN
'06 Jetta, DSG, Package 0
DATE: 8-26-06
Year: 2006
Make: vw
Model: Jetta, pkg 0
Date of auto production: 03-06
Engine code:
(paper label, now w/ clear tape over it)
BRM 037 042
handwritten: 775 in the box, and -1,6 next to bar-code.
27-01-06 16:10
Transmission Code: owners manual never filled in at dealer!
FTE 3VZ MX -on label behind battery
HXU -on options label in spare wheel well
DSG Production Date: 03.03.06 ?
1K1 614 105 AR
need to crawl around to find label that matches rjdell's.
New or Used? new, 5-06
Miles when purchased: 55
Current miles: 88k+
Area of country: Chicago western suburbs
Fuel Statistics: best: 43mpg, worst: 33
Comments:
2-13-07:
Love it Love it Love it! in dry weather.
In 10" of snow, I want a 'real' manual tranny! It gets old fast, arguing with the computer about 2nd or 3rd at 10-15 mph on the Interstate!
9-30-11: No problems or issues (knock wood)
12-12-11: JasonTDI
did DSG service and timing belt at 78K
(I also bought into the "sealed transmission" theory, so didn't change fluid at 40K)
Current miles: 88K
+ (7-12)
Also, I always ALWAYS use the e-brake - there's no functional lock-out to keep the car from rolling a bit in P, and then being hard to shift back into gear.
BillsTDI
Raleigh, NC
2006 Jetta TDI with DSG
Date: 8/27/2006
Year: 2006
Make: VW
Model: Jetta TDI
Date of auto production: April 7, 2006
Engine code: BRM
Transmission code: HXU
Date of DSG production: ???
Purchased new or used: New
Miles when purchased: 268
Current miles: 4650
Area of country: Raleigh, NC
Fuel stats: best, 47mpg, 90% highway; worst, 35mpg, 90% city---AC always ON!
MileageLover
Mobile, AL
06 Jetta TDI
Date: 8/27/2006
Year: 2006
Make: VW
Model: Jetta TDI
Date of auto production: 6-06
Engine code: BRM
Date of DSG production: Too lazy to look - will update later
Miles when purchased: 45
Current miles: 1500
Area of country: Mobile, AL
Fuel stats: 42.5 AVG mixed, but mostly hwy @ 50-70 mph
No problems that I can tell - does roll back like a manual on inclines like someone else mentioned.
jddaigle
Denver, Colorado, USA
No TDI Anymore
DATE: 27 August 2006
Year: 2006
Make: Volkswagen
Model: Jetta
Date of auto production: February 2006
Engine code: BRM
Date of DSG Production: 22 December 2006
Miles when purchased: 25
Current miles: 3250
Area of country: Denver, Colorado, USA
Fuel Statistics: 45/39/36 - 90% Urban driving.
No problems!
Leedogg
Brewton, AL
Present: 05 Passat TDI Past: 06 Jetta TDI
DATE: 28 August 2006
Year: 2006
Make: Volkswagen
Model: Jetta
Engine code:
Transmission Code:
Current miles: 14,000
Area of country: Brewton AL
Fuel Statistics: 43/39/37
hkbladelawhk
Phoenix, Arizona
2014 Golf TDI
DATE: 9/1/2006
Year: 2006
Make: VW
Model: Jetta TDI
Date of auto production: Unknown
Engine code: Unknown
Transmission Code: - They never gave me my owners manual
Date of DSG Production: - :-(
Miles when purchased: 400+
Current miles: - 800+
Area of country: - Arizona
Fuel Statistics: - So far I've calculated only about 24...odd...
Tim Birney
Dearborn Heights, MI
05.5 TDI
DATE:
Year: 2005.5
Make: Volkswagen
Model: Jetta TDI
Date of auto production: - 08/04
Transmission Code: - Too lazy to look
Date of DSG Production: - Too lazy too look
Miles when purchased: 15
Current miles: - 14,900
Area of country: - Midwest, USA
Fuel Statistics: - overall average 39.2 MPG
9-2-2006 No problems of any kind with any of the systems on this vehicle.
BioThomas
Humble, TX
'06 Jetta TDI
Date:09/02/06
Year:2006
Make:VW
Model:Jetta
Date of auto production:03/06
Engine code:BRM
Transmission Code:
Miles when purchased: 27
Current miles: 5,400
Area of country: Humble, TX
Fuel Statistics: 43 MPG daily commute.
I am not sure if this is supposed to be the way it is, but when I slow down after a long drive, it seems to downshift kind of hard with a funny noise. Other than that, I enjoy it tremendously. Just wish I could start off in second, because first is a little short for me.
Edit: 10/29 - updated production date.
Peterjac177
southern wis
06 jetta TDI
date - 9/02/06
name - peterjac177
year - 2006
make - VW
model - jetta tdi
date of auto production - 3-06
engine code - BRM
date of DSG - 026/23/12/05
purchased - new
miles when purchased - 150
current miles - 8400
area of country - mid west
fuel statis - 49.25/45.4/41.0 :D
El Dobro
NJ
2017 Bolt EV, 2015 Spark EV
Date: 9/4/06
Year: 2006
Make: VW
Model: Jetta TDI
Date of Auto Production: 11/05
Engine Code: BRM
Date of DSG Production: 036/18/10/05
Purchased New or Used: New
Miles When Purchased: 40
Current Miles: 6535
Area of Country: Perth Amboy,NJ
Fuel Statistics: 47.3/40.8/35.9
Transmission runs just fine. I use all three modes, depending on the conditions.
JustLuckey
North GA
Non-VW: 2016 Ram 1500 Ecodiesel
DATE: 09/04/2006
Name: Warren (JustLuckey)
Year: 2006.5
Make: VW
Model: Jetta
Engine code: BRM
Date of DSG Production: - 036/18/05/06
Purchased, New or Used: - New
Miles when purchased: 22
Current miles: - 100,000 (since Sept 2nd, 2006)
Area of country: - Northeast USA, Northeast PA (Milford, PA)
Fuel Statistics:
Best: 51.22 mpg (all highway, with ~41,000 miles on the odometer, 65-70mph)
Avg: 45 mpg
Worst: 39 mpg (mostly city, this was with less than 1,000 miles on the odo)
Trans is fine, I use 'D' Mode 95% of the time. The other 5% is Manual mode.
Evolution
Raleigh, N.C.
2015 Passat TDI SEL, Platinum Gray
DATE: 09-05-2006
Year: 2006
Make: VW
Model: Jetta
Date of auto production: - Will have to look " usually month and year " unless you know the day
Engine code: Will have to look
Transmission Code: - Will have to look “located in owners manual next to engine code
Date of DSG Production: - Will have to look “located on top of trans just below and beside the battery – is visible with flashlight”
Purchased, New or Used: New in Oct. 05
Current miles: - 21,200
Area of country: - North Carolina, Raleigh area.
Fuel Statistics: - Worst to date Average = 34 mpg. Best to date Average = 58 mpg.
eli
North USA
2017 Chevy Cruze TD Stickshift
06 Nb Dsg
9/5/2006, no problems with DSG so far.
Year: 2006
Make: VW
Model: NB
Date of auto production: -later
Engine code: later
Transmission Code: - later
Date of DSG Production: - later
Purchased, New or Used: New, July 2006
Miles when purchased: 10
Current miles: - 6000
Area of country: - New England.
Fuel Statistics: - 41+ mpg
