Smokin'Joe
- Joined
- Jun 5, 2000
- Location
- Lisbon, Portugal
Hi,
I have a Seat Ibiza 90hp (same body shell as Golf Mk.2)wich has rear drum brakes. The hubs are 4 bolt pattern both on the wheel side (pcd 100) and suspension side.
I would like to know if it is possible to upgrade it easyly
to disk brakes using some used ones from a Golf Gti/G60/VR6 or Ibiza 110. By this I mean just taking the wheels out, unbolting the hub from the trailing arm (four bolts,same pattern as Golf) bolting the disk hub, bleeding brake sistem and then go out to the skid pad to adjust the front/rear braking force, or is it much more difficult than this
Thanx in advance
Joe
Thanx in advance
Joe
