T toastyjosh Veteran Member Joined Feb 8, 2009 Location Northern NM TDI 2003 silver 2door golf Oct 30, 2011 #1 So my DRLs will some times work and then other times not work. The lights work fine when I turn them on. Anyone have this problem before? Thanks
G graeme86 Veteran Member Joined Jan 14, 2005 Location Brisbane, Australia TDI Not yet - fuel is too cheap! - 3.2 VR6 R32 Nov 1, 2011 #2 US cars are also wired up to switch off the DRL when you pull the handbrake on. Is that possibly what you are noticing? Otherwise, your DRL relay may be faulty.
T toastyjosh Veteran Member Joined Feb 8, 2009 Location Northern NM TDI 2003 silver 2door golf Nov 1, 2011 #3 It is when I pull the hand brake off, the DRLs do not come on. Ok will check drl relay. Do you remember which relay it is? Thanks
T toastyjosh Veteran Member Joined Feb 8, 2009 Location Northern NM TDI 2003 silver 2door golf Nov 1, 2011 #4 Nevermind I found it....relay 173. I should get a euro switch while I am at it. http://forums.tdiclub.com/showthread.php?t=103477&highlight=DRL+relay
