The LED replacements will be nearly as bright as DRL as for headlights.
The voltage reduction for use as DRL is created by a 'series resistance wire', nothing more than a long length of small gauge wire that has about 1/3 the internal resistance as the incandescent filament. The 12 volts to the headlights now has another resistance to pass through before getting to the headlight. The result is about 4 volts being used to 'illuminate' the series resistance as infrared heat and about 8 volts being the potential at the filament.
The LED will use so little power that the small gauge series resistance wire is effectively no resistance to that greatly reduced amperage draw. There'll be next to no voltage drop at the ends of the resistance wire leaving nearly the full 12 volts at the LED capsule.
