I have a 2005 Jetta4 1.9tdi AHF engine code with 290 000 km. Had a turbo problem, shaft snapped while driving. I managed to get home,parked the car wasn't leaking oil even when I started it a few days after the incident just wanted the battery not to go flat(didn't drive the car,let idle for about 5mins and switched off).
Then I eventually took off the turbo to access the damage,it was bad the turbo shaft was split in two. I started the car without the manifold started and I hooked back the manifold after I took off some photos off the turbo to find a replacement. Then on two occasions I started the car with the same broken turbo that was when oil started dripping off the exhaust pipe. Managed to find a replacement turbo,bolted it up and still it's dripping oil off the exhaust pipe,it's not smoking not even little smoke to notice. It's revving well enough to confirm the turbo is working,can rev to 3000rpm at idle.
Can somebody point me into the right direction so I can know where exactly my problem could be.
