dreaded P2459 code....
18inchapes
new jersey
2015 Jetta TDI SE
Hi gang,
I have a thrread started about this issue listed "dpf filter clogging"...ive had issues posting so i just decided to make a new thread.
So anyway, ive been having the p2459 code pop up every few days.. ive replaced both pressure sensors already, and i also blew out the hoses with comressed air.
The last time i blew the lines out, i managed to get a few weeks before the code popped up again.
i did a scan using my Vag-Comm.
Can you guys have a look at the scan and see if anything pops out?
is it just time to "disable and tune"?
scan to follow..
Also, where is EGR valve 2 located?
Thanks in advance, Jeff
18inchapes
new jersey
2015 Jetta TDI SE
Tuesday,27,May,2025,15:27:24:31751
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
www.Ross-Tech.com
VIN: 3VW3A7AJ5FM228590 License Plate:
Mileage: 372790km-231640mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 04 05 08 09 15 17 19 25 2B 2E 44 56 75 77
VIN: 3VW3A7AJ5FM228590 Mileage: 372790km-231640miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
75-Telematics -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 016 B HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9468
Revision: 8AH20--- CVN: A15D80E838D3FF82B866C2AD
Coding: 01190012042410085000
Shop #: WSC 08227 444 00000
ASAM Dataset: EV_ECM20TDI01104L997016B 004002
ROD: EV_ECM20TDI01104L997016B.rod
VCID: 323E1058A4A8A1EA49E-8066
VINID: 0E69C344745A156742088149000F528BA8
2 Faults Found:
5964 - EGR Valve 2 (N213)
P045A 00 [01100000] - Electrical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
8863 - Particulate Filter
P2459 00 [11101101] - Regeneration Frequency
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 372668 km
Date: 2025.05.25.
Time: 12:44:33
Engine speed: 1999.50 /min
Normed load value: 20.8 %
Vehicle speed: 78 km/h
Coolant temperature: 89 °C
Intake air temperature: 87 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.220 V
Unlearning counter according OBD: 40
Exhaust gas jet volume in particle filter: 150.5 m³/h
Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 117 hPa
Particle filter: soot mass measured: 22.33 g
Particle filter: soot mass calculated: 22.33 g
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 0 hPa
Particulate filter input: temp. sensor 1: bank 1: raw value: 256.8 °C
Particulate filter output: temp. sensor 1: bank 1: raw value: 253.2 °C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V4.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C49240002851002ED92190042A1100012
Shop #: WSC 00066 000 00000
VCID: 045286804E1CDF5AAB2-8050
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 20
Mileage: 372467 km
Time Indication: 0
Date: 2019.10.15.
Time: 16:06:40
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 51064
Count: 65280
Count: 64765
Count: 0
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0344154414 Dataset Number: 160116v____ 0002
Coding: 000F0F
Shop #: WSC 00066 000 00148
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 3728214C4FCA44C27E0-8062
No fault code found.
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 CA HW: 5C0 820 047 CA
Component: J301 Klimaanlage 0207
Revision: 2001001S Serial number: 00000002370021
Shop #: WSC 00066 790 00017
VCID: 619CAF14BD4E6A72E04-8034
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 E HW: 7H0 937 090 A
Component: BCM PQ25 Max3 H74 0725
Revision: B8074001 Serial number: 27013258140544
Coding: 7B994B9A08AB0B0008382080240884C50F86702E60000050B0A050022844
Shop #: WSC 42380 001 1048576
VCID: 303A1A50AA2493FA3FA-8064
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14102585140828181250
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584140903134843
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH000CA6CA
Coding: 180000
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H04 0019
Serial number: 2211406590000370AD1B
Coding: 280000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587140825092100
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586140910193106
Coding: 800000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD02RE8. Dataset Number: 160003V____ 0313
Coding: 00004B33
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72BED0586428E1EA89E-8026
Seat occupied recognition:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J140001C0XE01
Coding: 303345
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME1A5A5D45ZZZ3
Crash sensor for side airbag: passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME53520A47ZZZU
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME7A223530ZZZL
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME20143530ZZZ8
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME072E4D30ZZZ.
Crash sensor for front airbag: passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME36384D30ZZZZ
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 954 A HW: 5C6 920 954 A
Component: KOMBI H04 0807
Serial number: 00000000000000
Coding: 270A01
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2C020E20868CF71A032-8078
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090 A
Component: GW-K-CAN TP20 H74 0725
Revision: B8074001
Coding: 102200
VCID: 70BADA506AA4D3FA7FA-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0807
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8EC8384CF8292A31E-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000206489004
Coding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 303A1A50AAA493FA3FA-8064
Address 2E: Media Player 3
Cannot be reached
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392C2774755E52B2884-806C
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 H HW: 1K0 035 188 H
Component: Radio Prem-8 H07 0009
Revision: -----12S Serial number: VWZ4Z7P3615059
Coding: 01000440020006
VCID: 2D040324BD16FE1214C-8078
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140527 Dataset Number: V03935196FH 0010
Coding: 02630102C2163A007F1606000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 001010
ROD: EV_OCULow_001_VW12.rod
VCID: 53F075DCFB7288E2628-8006
1 Fault Found:
2103041 - Control Module
B1788 F0 [00001001] - Start Prohibition Deactivated
Freeze Frame:
Fault Priority: 8
Fault Frequency: 1
Reset counter: 238
Mileage: 372795 km
Date: 2025.05.27.
Time: 15:23:56
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666491199 Dataset Number: 5N0035729E 0001
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:59, VBatt start/end: 13.8V/13.8V)-----------
------------------------------4 Faults Found-------------------------------
Address 01: Engine Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 997 016 B HW: 04L 907 309 K
Component and/or Version: R4 2.0l TDI H20 9468
Software Coding: 01190012042410085000
Work Shop Code: WSC 08227 444 00000
ASAM Dataset: EV_ECM20TDI01104L997016B 004002 (VW36)
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 372668 km
Date: 2025.05.25.
Time: 12:44:33
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 372668 km
Date: 2025.05.25.
Time: 12:44:33
LukesCRUA
Toronto Ontario Canada
2015 Audi A3
I bet the egr system / intake manifold needs a good cleaning. That’s what I’m leaning to on my car given our cars have the same mileage and exact engine code . Restricting airflow, running rich, injecting more fuel, clogging up dpf faster .. just a possibility
LukesCRUA
2015 Audi A3
Hello. Did you fix the issue with excessive regeneration? I’ve been running a little higher cetane diesel fuel but no major difference yet
Also while I’m cruising on the highway watching the soot mass measured slowly creep down during regen, around 110km/hr, if i just coast in neutral, near the end, the soot load drops down very fast to almost 6 grams and finishes the regen.
