Well, just what I was afraid of. Problem is back. Made it 275 miles then out of nowhere the check engine light and P0087 code is back. Reattached my VagCom and gauge. Found the lift pump psi is back down to 5 psi. I'm really not sure the lift pump is faulty. After reviewing my testing I noted that I had not checked the Fuel Overflow Valve in the HPFP. Remove it and found it rattles when you shake it. PM with dweisel indicates this valve should not rattle. Tried to test the valve on the bench with air psi but could not go past 57 psi with 125 inlet psi either due to the hose not sealing or the valve is bypassing. There is not much room to seal the hose on and air would start leaking around 30-35 psi. The hose seal area was so close to the discharge ports on the valve I could not tell which one was leaking. Any one know where to buy this valve? Local salvage yard will not sell just the valve off of the HPFP. Thanks.
Valve removed from pump.
Testing overflow valve on bench
