DPF won't regen
joesaiditstrue
Illinois
2013 Jetta Sportwagen 2.0L DSG
2013 JSW TDI w/ DSG
No Check Engine Lights (yet) but saw this as a yellow/temp code in the scan tool app
P2002
Particulate Trap Bank 1, Efficiency below threshold
P1006
I immediately took the car for a 25-30min drive hoping to force a regen. Took it on the highway, was cruising at 75mph for about 10 min.
Came back home. No regen had ever started as far as I could tell by keeping an eye on the RPMs. It always dropped down to 800-820. DPF Regen always made my RPMs go up to 1k. Soot level sitting at 23.2g, it was at 22g before the drive
Any advice? I don't have VCDS, I have Carista but it doesn't give me the custom option to add the DPF feature (I'm using a 3rd party OBDLink MX)
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
Try clearing the codes for the ECU when the car is warmed up and to see if the car will regen.
borninabus
Arizona
-2013 JSW 6MT- -2006 Jetta DSG-
my wagon is like 80+ mph to get the rpms up above 2200 in 6th.
2200-3300rpm is the sweet spot for (highway) passive regen--at least that's what i've read.
try going 75 in 5th.
joesaiditstrue
Illinois
I'm afraid to take the car out again. What if the DPF light comes on and I get stranded in limp mode.
ksing44
Southeast PA
2010 Golf TDI
I think I remember that you can initiate a regen by driving 45 mph in 4th gear for an extended period of time. I think it might even be in the owners manual, but I didn't check.
Porch
Asheville, NC
2011 jetta sportwagen tdi 6spd
You kind of always have to drive like you're trying to do a regen, if you still have your dpf. 1800-2200 rpm on cruise control on the open road, every time you have the chance. For now, go to an open highway and cruise control in 5th at 2200rpm for like a half hour, and see if that helps.
joesaiditstrue
Illinois
I'll probably try it tomorrow, I'm just worried about the car going into Limp mode while I'm on the highway
Also I found soot inside my tailpipe just now. I've read that's not supposed to ever happen?
joesaiditstrue
Illinois
Here's what Carista is pulling off my ECU at the moment
ECU info obtained with Carista 7.3.1 for Android:
VIN: 3VWPL7AJ5DM630926
CAN network gateway
Part #: 7N0907530T
Component: J533 Gateway
Software version: 1632
ASAM/ODX identifier: [none]
Coding: 352002 (hex)
[No fault codes]
Engine
Part #: 03L997030E
Component: R4 2.0l TDI G000
Software version: [none]
Coding: 50078 (decimal)
Fault codes:
P2002 Particulate Trap Bank 1, efficiency below threshold
P1006 Torque Difference Cylinder 3, Limit Value Exceeded
Transmission
Part #: 02E300062B
Component: GSG DSG AG6
Coding: 20 (decimal)
[No fault codes]
ABS
Part #: 1K0907379BL
Component: ESP MK60EC1
Software version: 0152
Coding: 114B600C492500FA881406E6921F0042B70000 (hex)
[No fault codes]
Power steering
Part #: 1K0909144P
Component: EPS_ZFLS Kl. 70
Coding: [none]
[No fault codes]
Steering angle
[ECU not present]
Steering wheel
Part #: 5K0953521BR
Component: LENKS.MODUL
Software version: 0140
ASAM/ODX identifier: EV_SMLSNGVOLWSXS
Coding: 100A140000 (hex)
[No fault codes]
Airbags
Part #: 5C0959655M
Component: AirbagVW10G
Software version: 0726
ASAM/ODX identifier: EV_AirbaVW10SMEVW360
Coding: 00004E42 (hex)
[No fault codes]
Instrument cluster
Part #: 5K0920973C
Component: KOMBI
Software version: 0705
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 270F01 (hex)
Fault codes:
13893888 Manufacturer-specific code
13636096 Supply voltage too high
Navigation
Part #: 1K0035274D
Component: RNS315-NAR
Software version: 0319
ASAM/ODX identifier: EV_RNS315NARV2UDS
Coding: 04000401040007000000100A (hex)
Fault codes:
1048577 Manufacturer-specific code
1048669 Tuner for Satelite Radio
Radio
[ECU not present]
Media player
Part #: 5N0035342F
Component: SG EXT.PLAYER
Software version: 0530
Coding: 020100 (hex)
Fault codes:
00447 Function Limitation due to Voltage to High
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000007 (hex)
[No fault codes]
Heater & air conditioning
Part #: 7N0907426BH
Component: AC Manuell
Software version: 0505
ASAM/ODX identifier: EV_ACManueBHBVW36X
Coding: 0010002002 (hex)
Fault codes:
9481200 Refrigerant pressure (too low)
Central electronics
Part #: 5K0937084J
Component: BCM PQ35 B
Software version: 3068
Coding: 6F380E1F802F3EC4008800C17000004449000086575D05F064802020A040 (hex)
Fault codes:
01134 Alarm Horn (H12)
01504 Bulb for License-Plate Light (X)
02394 Parking light left front (M1)
Central electronics 2
Part #: 7N0907532
Component: EZE_2
Coding: 050B0500 (hex)
[No fault codes]
Body/convenience system
[ECU not present]
Driver's door
Part #: 561959701
Component: TUER-SG FT
Software version: 0501
ASAM/ODX identifier: EV_TSGFPQ35BRFVW46X
Coding: 0004B5 (hex)
Fault codes:
65792 Manufacturer-specific code
Front passenger's door
Part #: 561959702
Component: TUER-SG BT
ASAM/ODX identifier: EV_TSGBPQ35BRFVW46X
Coding: 0004B4 (hex)
Fault codes:
Rear left door
[ECU not present]
Rear right door
[ECU not present]
Ignition authorization
Part #: 5K0959434B
Component: VWKESSYPQ35GP
Software version: 0902
ASAM/ODX identifier: EV_KESSYPQ35G
Coding: 030C0C (hex)
Fault codes:
1053192 Manufacturer-specific code
1053195 Manufacturer-specific code
Steering column lock
Part #: 5K0905861B
Component: ELV-PQ35
Software version: 0240
ASAM/ODX identifier: EV_ELVMarquMPVW36X
Coding: 4900000000000000 (hex)
Fault codes:
borninabus
Arizona
do you know what your warranty status is?
unfortunately, it looks like you need to address your failed DPF.
at least wipe the tailpipes clean and see if the soot comes back to confirm. the car won't leave you stranded, but if you drive for an extended length of time with the DPF clogged, it will eventually clog the EGR--P0401.
i know when mine was failed it was quite obvious, puffing smoke on the upshifts, soot on the bumper, yeah.
joesaiditstrue
Illinois
emissions warranty has passed
joesaiditstrue
Illinois
So I drove it around for about 30 min, kept RPMs between 2200 and 2800. no active Regen started. I decided to clear the ECU faults and disconnected and reconnected my OBD2 scan tool
it's now showing 0.0g of soot. maybe it did a passive Regen by keeping the RPMs at that specific range for almost 30 min? I don't think clearing the ECU faults would reset the DPF Soot reading
I'll probably have the car looked at here soon, my VW mechanic knows a guy who does the delete for you, so..
hskrdu
Maryland and New England
I do not have a Mk6. That being said, a passive regen in a Mk7 wouldn't effectively clear out the DPF to proper threshold numbers as you describe. Using driving 'style' to initiate an active regen would do it, but it sounds like your ECU is preventing it because of the numbers reported from the DPF. I would try to find someone with VCDS (or buy a cable) and follow the RT forums for initiating an active regen, which is likely what VW would try to do if the car is still within parameters.
joesaiditstrue
Illinois
Are you monitoring your coolant temps? It won't regen at all if your tstat has failed.
yeah coolant temps are fine. the P2002 code went away last night when I started the car for some reason. the dpf light never came on, it was just showing up as a temporary trouble code on my scan tool
the only code showing up now is the P1006
borninabus
Arizona
not familiar with the P1006 code off hand.
i'd stick with my recommendation of cleaning out the tailpipes to see if soot appears.
joesaiditstrue
Illinois
So I've got my VCDS installed on the laptop and plugged in. Having some issues with checking my DPF stats.
I clicked on Engine, Basic Settings
I typed in 241 under the Group option and clicked GO
It's saying "ERROR GROUP 241 NOT AVAILABLE"
Any tips?
Francobenz
Montréal, QC, Canada
Golf TDI 2003
joesaiditstrue
Illinois
joesaiditstrue
Illinois
108 and 241 don't work. It's acting like it doesn't matter what code I input.
Any VCDS experts around?
joesaiditstrue
Illinois
Did you select Block 099 first, and otherwise follow the Rosstech instructions?
Wow, I'm an idiot. I figured it out. It says my Soot load (Calculated) is 7.5g and Measured says 0.0g
Why did I have a P2002 code if these values look normal?
Wonder if there's anything else I can check
hskrdu
Is there an RT procedure to force an active regen? This what I would attempt, unless your DPF has returned to normal operation (despite what the readings might be).
joesaiditstrue
Illinois
Is there are RT procedure to force an active regen? This what I would attempt, unless your DPF has returned to normal operation (despite what the readings might be).
Waiting for the engine to heat up to proper temp and then gonna try to force active Regen.
