DPF sensors numbers 2015 passat
MAXRPM
US
00 Jetta and 99.5 Golf, 2015 Passat TDI,BMW 2
About a year ago 1 of my 2 DPF sensors melted completely the other one is semi melted too, can't see the numbers off either one, both the part numbers are missing one is irecognizable, back then I was able to buy one getting the number from the stealership, im not so sure it is the right number, im getting DPF sensor cel, and I've been trying to get the right part #, from different stealerships so it is confusing, and they are giving me all kinds of numbers, does anybody here happen to have the part numbers on both sensors, the one I replaced does not seems to be the right one, cause it's got 2 hose connection and I only have one hose, so I'm giving up trying again with the stealer, any help would be appreciated
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
I assume that you are trying to say pressure sensors, so it should be this
Original was probably this rev
076 906 051B
But if you say you only have "one connection", I doubt that you're looking at a pressure sensor.... are you sure you're not getting confused with the EGT sensor?
TurboABA
Kitchener, ON
.... or you're looking at the boost\air pressure sensor and confusing it with a differential sensor for the DPF...... that's the only similar looking sensor that I can guess it could be if it only has one nipple on it.....
What codes are your throwing? Any pictures of what you're looking at?
MAXRPM
US
Yes pressure sensor
MAXRPM
US
Number I got from stealer and I bought is 03L 906 051D, it looks like the one in the pic from ECS, and it's got the same number but I can only connect 1 hose there are not 2 hoses to connect to it
TurboABA
Kitchener, ON
Keep looking... you can't have a "differential" pressure sensor tell the difference between TWO pressures if you're only giving it ONE signal.....
Start at the DPF if you need to, and trace the pipes until you find your missing hose..... it needs to see the pressure before and after the DPF not just one of them.
MAXRPM
US
Well I got 2 hoses but I also got another sensor with 1 hook up so I'm still missing 1 more hose
There is only one DPF differential pressure sensor. The other one is for the EGR system.
On the CVCA, I do not know which is which, but the two part numbers I have are:
03L-906-051-B
076-906-051-B
But my ETKA is sadly outdated so either or both of those numbers may have been superceded by now.
My gut reaction though when you said one was "melted" is that you have some other issue going on that caused that.
MAXRPM
US
hot days over 100deg those sensors tend to melt, members are reporting that and it happened to my passat, those sensor should have been made aluminum or metal,
TurboABA
Kitchener, ON
Kind of weird that this happens to so many people, yet you can't even find part numbers or identify which sensors you are talking about.... it's probably 100deg and you can't see or something.....
You engine doesn't care if it is 60 F or 120 F. It is dealing with temps FAR higher than either of those. Those sensors should never be exposed to any levels of heat that would melt them. Those type of differential pressure sensors have been in use on many cars for decades (even my 1996 F150 has one!). And they used to be aluminum, and they corroded up and blocked themselves off due to moisture.
You have something else going on causing this, and keep in mind it may simply be a design flaw that has been made worse due to Dieselgate changes (like the heater cores that keep clogging up).
TurboABA
Kitchener, ON
Or some butchers were already under your hood and removed the heat shielding sleeves\wraps.... on my Jetta, my sensors are behind the reflective shield since they sit right behind\above the turbo.
