Really appreciate the instructions outlined in this thread. 2013 Sportwagen TDI 92,000 miles.
DPF light came on yesterday. Codes P2002, P1A58, Sooty tailpipes. Willing to DIY within reason (previous thermostat replacement perhaps hardest repair I've performed-no front end removal). Will attach VCDS scan. Should I bother with regeneration on highway? Thanks, John
Sunday,01,October,2023,12:15:37:23487
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: 3VWPL7AJ3DM691725 License Plate:
Mileage: 148080km-92012mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJ3DM691725 Mileage: 148080km-92012miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H15--- Serial number:
Coding: 0050078
Shop #: WSC 34115 003 1048576
VCID: 30391E007626E87ABFB-8064
VINID: 0E69E070745A0D47462411C214B0A5E00C
2 Faults Found:
008194 - Particulate Trap Bank 1
P2002 - 007 - Efficiency Below Threshold - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 147731 km
Time Indication: 0
Date: 2018.02.14
Time: 10:26:46
Freeze Frame:
RPM: 1955 /min
Speed: 42.0 km/h
(no units): 56.1
(no units): 25.5
(no units): 2.28
Pressure: 115 mbar
Pressure: 26 mbar
006744 - NOx Catalyst
P1A58 - 000 - Regeneration Required
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 11
Reset counter: 255
Mileage: 148024 km
Time Indication: 0
Date: 2018.02.20
Time: 21:06:33
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 3.5 %
Pressure: 968.0 mbar
Temperature: 33.3 C
Mass Air / Rev.: 1100.0 mg/str
Temperature: 44.1 C
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9430
Revision: 05651213 Serial number: 00001302211189
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 1471B290E27E345ABB3-8040
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492B00FB881206E6921E0042B70000
VCID: 7DA7F734FDF4D51264D-8028
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010002002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 7BA3F92CE360DB225A9-802E
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 3068
Revision: BG021001
Coding: 2F380E1A802F3EC4008800C17000004449000086535D0560648020200040
VCID: 392F2324A95C2932085-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 29051 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R01WVB1 Dataset Number: 1KM003v__B_ 0047
Coding: 00004E42
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C213A30A6EE1C1A133-8068
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00007ZF000
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME48565378ZZZ$
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME1B6A047BZZZ1
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME071D5A2FZZZY
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME03015A2FZZZI
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME1231342FZZZ7
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME5D1C342FZZZW
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90440MDJ000EN Dataset Number: 5K0953507AH D005
Coding: 188A140000
Shop #: WSC 00066 000 00187
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B5E818D842864A257-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0211622 FLE 20130418
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 973 C HW: 5K0 920 973 C
Component: KOMBI H05 0705
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 313F1B0471ACE172B05-8064
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 15051303270068
Coding: 352002
VCID: 74B1D210CEBE945A1B3-8020
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RMCEJ07
Coding: 0000002
VCID: 7EA5F038FCF2CE0A7D7-802A
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0705
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DCC689CFA52AAB1F-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664530452
Coding: 010100
VCID: 2A0D0C685CFA92AA71F-807E
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0006755446
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BE399AC43A03B223A9-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1509
Serial number: 00000007785366
Coding: 000490
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372B251C93483F42FE1-8062
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0006742269
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CE19AB046AE3C1A333-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1509
Serial number: 00000007777655
Coding: 000490
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H02 0010
Revision: -----16S Serial number: VWZ4Z7M3273335
Coding: 01000400040007
Shop #: WSC 55831 001 1048576
VCID: 6491A2507E5E04DA8B3-8030
1 Fault Found:
00625 - Vehicle Speed Signal
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 48
Time Indication: 0
Date: 2063.15.31
Time: 15:02:56
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664581142 Dataset Number: 7P6035730K 0001
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A2D3C28ACDA222A01F-806E
End----------(Elapsed Time: 01:15, VBatt start/end: 14.0V/14.0V)-----------
