George56
Background: 2015 Passat TDI with 110,000 miles. Car has a salvage title due to some front engine damage that was repaired (not very well IMO). I have owned the car for 3 years and driven it 50,000 miles. All maintenance up to date, never had a problem that caused a CEL. Timing belt, water pump, etc… replaced 9 months / 18,000 miles age - DPF sensor replaced at this time due to cracked plastic while working on the timing belt. Replaced sensor was Febi Bilstein OEM quality from FCP Euro.
Scheduled service to get the DPF replaced for the phase 2b emissions fix. Dealer replaces DPF. Go to pick up the car and had to argue with the dealer about the top half of my windshield washer reservoir missing, the coolant expansion bottle not bolted down, coolant expansion tank filled to 2 inches from the top, the exhaust sensor heat blanket missing, and very wispy “smoke” coming from behind the engine IVO the exhaust manifold / DPF connection.
Dealer grudgingly agrees to investigate/fix these issues and had to replace the valve cover under warranty due to 3 cracks on the backside where the “smoke” was coming from.
Pick up the car and drive it for a few days (about 300 miles) and it throws a CEL for P2002 (Particulate trap bank 1 efficiency below threshold) and P240F (EGR system response too slow). I schedule with the dealer for diagnostics and repair. While waiting to bring it in the car is not driven.
Bring the car to the dealer and they insist that they can’t run diagnostics because my replaced DPF sensor isn’t stamped VW. After much discussion they replaced the sensor (no charge) with a VW stamped sensor cleared the codes/CEL and drove the vehicle about 3 miles for their test drive. They claim the CEL stayed clear during the drive. They return to the shop and lift the car. They then tell me that when backing the car away/off the lift the CEL came on for a crankshaft/camshaft timing error.
They stated that they had no idea what happened but recommended checking the timing and I agreed - left the car at the dealer over the weekend since I don’t want to turn it on with the timing in doubt.
Today they call and leave a message telling me that the timing is off / jumped by 2 teeth and that the water pump is leaking.
I am 100% positive that everything was perfect when I did the timing belt (tensioned properly and the camshaft and HPFP pins fit in their holes with the crank locked at TDC and reverified 3 times by rotating by hand 2 crank revolutions and inserting the crank lock and both pins). They didn’t mention how much the water pump was leaking. I haven’t ever seen any water pump leakage and haven’t needed to add any coolant for the last 15,000 miles after flushing the cooling system and replacing the thermostat, heater core for the 3rd time, and oil cooler. I left a message asking for pictures.
What are y’all’s thoughts about the this sequence of events and the car. At this point I don’t understand why everything seemed to be fine until the dealer touched the car also I’m completely frustrated with this dealer - the next closest is 80 miles away.
