DPF Regen Frequency P2459
passdatdi
US California
2013 CRKA 2.0
Hi all. So 2013 Passat 2.0 TDI CKRA been having CEL come on for this code. I will post a scan but the soot is 24.9 g as per VCDS. When I scan it with my AUTEL scanner, the soot comes out to 00.5 g. Not sure what's up with that.
The CEL would come on after only 7-10 miles. When I do a Force Regen the CEL won't come on for about 100 miles.
I know this could be a variety of things triggering the CEL. But is there a guide/check list on trouble shooting with VCDS to try and pin point as much as possible. I am experiencing a whining noise coming from the turbo. Being that these are attached to each other not sure if the turbo not operating normally could trigger the DPF code. I don't have turbo trouble codes at all and besides the CEL coming on, car runs fine.
I performed a couple of tests on basic settings with VCDS:
NOx sensor-aborted-safety reasons/malfunction.
Test of oxygen sensor-Finished correctly/End of system test: system not OK.
Test of charger air pressure control-Finished correctly/End of system test: system not OK.
Not sure what to make of these or if related. Any ideas, comments, suggestions appreciated.
Tom in PT
Twilight Zone, WA State
There has been quite a bit of discussion of this code and excessive regeneration of the DPF. Do some searching. One thing to consider is the lines to the pressure sensors that trigger regen can get blocked with carbon, or the sensor itself can go bad. I have had both of those situations. I eventually installed a Kerma tune about 3 years ago and have not had any issues since then, regens at about 430-450 miles every single time.
passdatdi
US California
2013 CRKA 2.0
Here is a recent scan:
Tuesday,03,June,2025,08:18:59:01454
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
www.Ross-Tech.com
VIN: 1VWBN7A32DC076445 License Plate:
Mileage: 229360km-142517mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
VIN: 1VWBN7A32DC076445 Mileage: 229360km-142517miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H23 9982
Revision: 71H23--- Serial number: CVN: D240C61F5C3E0D04
Coding: 001D0012042400000000
Shop #: WSC 22194 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009H.rod
VCID: 3B233CC303E5FA329A8-806E
VINID: 0669D27874430944C01C6104147C1ACF14
1 Fault Found:
8863 - Particulate Filter
P2459 00 [11101101] - Regeneration Frequency
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 229089 km
Date: 2025.06.03.
Time: 23:52:29
Engine speed: 2153.50 /min
Normed load value: 70.6 %
Vehicle speed: 114 km/h
Coolant temperature: 109 C
Intake air temperature: 37 C
Ambient air pressure: 910 mbar
Voltage terminal 30: 14.320 V
Unlearning counter according OBD: 40
Exhaust gas jet volume in particle filter: 346.9 m /h
Particle filter: difference pressure: 314 hPa
Particle filter: soot mass measured: 24.12 g
Particle filter: soot mass calculated: 24.11 g
Particle filter: differential pressure: dynamic offset: 4 hPa
Exhaust gas temperature sensor 3: 441.9 C
Exhaust gas temperature sensor 4: 374.1 C
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9436
Revision: 05551213 Serial number: 00001209182057
Coding: 0000020
Shop #: WSC 09003 957 00200
VCID: 2411E7BF92DBA5CACB2-8070
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: C54BC0F549290000A30F03E8921E0042A71000
VCID: 7DA7F2DB5DF13402E4C-8028
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 561 907 426 A HW: 561 907 426 A
Component: AC Manuell H02 0101
Revision: 00001K07
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC_VW41.rod
VCID: 196FC64BA919E822684-804C
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0168
Revision: BL121001
Coding: 6F200E1B902B08D408880001160085480071008640A00560648060000C70
VCID: 74B1D7FF6EBB754A9B2-8020
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 240912 05 54 0403
Coding: 22300A
2 Faults Found:
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 243
Mileage: 224786 km
Time Indication: 0
Date: 2019.10.25.
Time: 01:56:17
Freeze Frame:
Term 15 On
Voltage: 13.35 V
ON
ON
OFF
OFF
OFF
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 45
Reset counter: 223
Mileage: 224786 km
Time Indication: 0
Date: 2019.10.25.
Time: 04:38:48
Freeze Frame:
Term 15 On
Voltage: 14.30 V
ON
ON
OFF
OFF
ON
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM056M09 Dataset Number: 560003v__A_ 0049
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FBBD893071D5692660-803A
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y120000LZBM0G
Coding: 303044
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME30653173ZZZL
Crash sensor for side airbag: passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME605A6273ZZZX
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME166B2520ZZZM
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME323B0B20ZZZM
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME64056E1EZZZ1
Crash sensor for front airbag: passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME261A761EZZZ%
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20121001302345
Coding: 088A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 76B5EDF77847675AA56-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 E HW: 561 920 970 E
Component: KOMBI H07 0705
Serial number: 00000000000000
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 1C61DF5FA62B9D0A732-8048
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 10111203290546
Coding: 461000
VCID: 76B5EDF778C7675AA56-8022
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0705
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
VCID: 6A8DC9873CFFB3BA31E-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663363842
Coding: 020100
VCID: 2A0D0987FCFF73BAF1E-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H35 0319
Serial number: VWZAZ2M4239743
Coding: 0400040104000B000000100A
ASAM Dataset: EV_RNS315NARV2UDS 001705
ROD: EV_RNS315NARV2UDS_VW41.rod
VCID: 2517FABB95615CC2DCC-8070
Data carrier:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V3_(0037) 0037
2 Faults Found:
1048669 - Tuner for Satellite Radio
B11CF 53 [00001001] - Deactivated
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 181
Mileage: 228372 km
Date: 2025.06.03.
Time: 06:14:08
1048642 - Internal Control Module Memory Check Sum Error
B2000 42 [00001001] - General Memory Failure
[ECU defect data memory failure]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 146115 km
Date: 2021.12.24.
Time: 22:27:47
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0005720211
Coding: 0404F5
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BE39C43E3A5DA32BA8-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Serial number: --------------------
Coding: 800000
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 290 3305
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 372B20F3334DDE527E0-8062
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030108
VCID: 6FBBD893079D5692660-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011223200119
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0005690344
Coding: 0404F4
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CE19F5FE6ABDD0AB32-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
End----------(Elapsed Time: 01:06, VBatt start/end: 14.0V/13.9V)-----------
jhort
CALIFORNIA
Passat
I did a live output of soot calculated and soot measured as I was driving to work. I noticed the soot levels elevate as I step on gas. Then the numbers start dropping as i let go of the gas. This is probably normal operation but i had never logged those. The trip was about 10 miles and soot levels reached steady from 1.96g (had just done a manual regen) and climbed to about 27g going about 70 mph on freeway. When I slowed down getting off ramp and on street traffic, the levels steadily decreased. At the time I parked car numbers were at about 5.47g measured and 5.84g calculated. Does this mean anything ?
GBaugh
Shelby, MT
VW 2.0L
What is the odometer reading? Keep in mind, the dpf can plug up with ash which continuously accumulates over the the life of the dpf. It is only soot that is managed with regens. On my 2012 ckra, the ash cleaning service interval is about 120,000 (mi or km?)
It appears that your aftertreatment sys is able to manage the soot load so that makes me wonder if the car is driven long enough to give the sys time to do its thing. What is the average mileage of your daily commute? Diesels with aftertreatment are not well suited for short drives.
The G550 dpf differential psi sensor value over a range of engine loads, as well as the exhaust gas temp values 1,2,3 and 4 during your regen would be helpful in evaluating health of aftertreatment control sys.
Whining noise from turbo is concerning. That could be a boost leak or it could be the turbine wheel rubbing the turbine housing due to a failed turbo which is VERY common on these passats. If you have a failed turbo, is it sending oil into the exhaust, causing your dpf to plug up? Inspection of turbine wheel can be done by using bore scope through lambda sensor port in top of the doc/dpf.
TurboABA
Kitchener, ON
I see you've recently blown away the engine controller codes.... why? What is it that you're conveniently not telling us? :unsure:
nedyalkov
Toronto
2015 Passat
My 2015 has been dropping the regen milage down to 30 km over probably a year. I purchased a used DPF had it cleaned for 150 CAD and then swapped them out and now my regens are close to 300 km
jhort
CALIFORNIA
Passat
Thank you! Now, this is helpful feedback. Odometer is just over around 142,000 miles as of last scan taken about three days ago. So, to clean the ash, is like doing it manually, like taking the dpf off and having it baked? I will log those parameters . Soon as i get a chance, will take look at that turbo with scope. BUt yes, I have considered possibility of oil getting into exhaust via the turbo; how , I dont know. I have to study the schematics how those are connected. I am getting no turbo fault codes, though. No smoke, no soothy tailpipes.
TurboABA
Kitchener, ON
Why? How do you expect anyone to diag stuff when you erase the diag info?
jhort
CALIFORNIA
Passat
It's same trouble code; P2459-Particulate filter-Regeneration Frequency; over and over, and over. Freeze frame almost identical every time. What more do you need to start actually giving some useful information? Maybe you don't know anything about this, and that's ok-really.
TurboABA
Kitchener, ON
You got me. Just keep going... You're doing great.
jhort
CALIFORNIA
Passat
"Fed up with the A-holes on TDiClub....You can't post a single thing without 20 veteran and new members pouncing on your ad, belittling your integrity, and price bashing your merchandise. It's truly pathetic....Amen. Most of the people there would rather just cut people up than offer helpful advice"-Diesel.Net. Ring a bell? But, I still think there some good people here.
TurboABA
Kitchener, ON
You insult people that are trying to help you by saying they don't know anything and now you're fed up?
jhort
CALIFORNIA
Passat
While had the oxygen sensor out checking the exhaust side of turbo for oil leaks-it was dry, no signs of oil leak. I wiped the soot off sensor and put it back. Sealed a small vacuum leak I found. I reset, relearned all options having to do with DPF, exhaust, etc.. in the basic settings. Over 80 miles now driving and no check engine light. However, when I scan car, it has the 2459 code stored there already just no CEL . Usually it would only take about 7-10 miles and light would come on. Don't know if something I did fixed it. Will see will keep driving. The whining sound does not go away though.
jhort
CALIFORNIA
Passat
Well, have since taken it to mechanic. His diagnosis was not helpful; he said maybe needs new differential pressure sensor and/or the DPF is plugged. I thought he would provide a more concrete diagnosis. I have been monitoring the differential pressure sensor and soot . When driving, sensor fluctuates between 60-450 hPA's. Kind of erratic too, say it may be at 220 hpa and suddenyly spikes to 290 or higher, then drops, all while gas pedal is steady. Soot doesn't really move from 16g. There is no smke from tail pipes, no soothy tail pipes, no DPF light. I guess I will install new sensor and see what result.
