jhort
Recently performed DPF cleaning at shop to see if it would alleviate symptoms. Shop puts DPF in some type of oven , blows the hoses/tubes. They said black stuff came out as expected.
I am noticing, and had not paid attention to this before, but soot measured and calculated are about even (~3g) first thing in the morning on idle. I press the gas to 2500rpm and meausred starts climbing while calculated stays about same. I got measured to 19g and let go off the gas. I figured it would begin to climb down but remained the same. If i stepped on gas again, it would continue to climb.
Took off to work, about 15 mile drive. Soot measured of course climbed until it got to about 25.3g. At that point CEL for P2459 came on. I was monitoring DPF Regen time since last regen and about the 13th mile, it started counting from 0 again. I looked at soot measured and it was climbing back down. Parked, kept engine on. At this time Soot measured was at 9g. Stepped on gas and got it up to 14g. Let go off gas and again, it remained.
So, i believe regens are happening since soot levels are coming down while driving and the countdown from last regen resets.
The fact that soot reaches 24g-25g in such short distance has to be an issue?
The fact that soot measured remains high after letting go off gas can't be right?
Ideas, suggestions, trouble shooting tips please. Thanks
The following is freeze frame on CEL fault:
