bloc
To those that have removed a two-piece DPF from a MKV Jetta Sedan, realistically how high does the car need to be in the air? Would a tall jack and standard jack-stands under the subframe be enough? Or is a lift absolutely necessary? I know you need to twist it 180 to clear the subframe, but am having trouble visualizing how much it'll "hook" downward as it is removed.
