DPF Problems
JPM
Millington, MI
2013 Passat
I have a 2013 Passat TDI that's throwing fits about the Adblue level. The tank is full, but it reads "150 miles to no start".... common old story. I'm thinking of doing a delete but thought I'd post my scan results here to see if anyone sees anything else that could be the problem before I go do it. Here are the engine codes I got:
5 Faults Found:
4531 - Fan 1 Control Circuit
P0691 00 [00100111] - Short to GND Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1 Mileage: 216271 km Date: 2127.14.31 Time: 17:08:26
Engine RPM: 926.00 /min
Normed load value: 42.7 %
Vehicle speed: 0 km/h
Coolant temperature: 15 °C
Intake air temperature: 49 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.200 V
Unlearning counter according OBD: 40
Air mass: specified value: 341.9 mg/stroke
Coolant temperature at radiator outlet: actual value: 7.2 °C Heat delivery temperature in cooling system: 10.7 °C Outside temperature: 8.5 °C
Coolant fan 2: activation: 0.00 % Coolant fan 1: activation: 10.00 % Fuel temperature: 11.7 °C
9639 - Control Circuit for Reductant Pump 1
P208A 00 [00100111] - Open Circuit
Not Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Priority: 2 Fault Frequency: 1 Mileage: 216271 km Date: 2127.14.31 Time: 17:08:27
Engine RPM: 918.00 /min
Normed load value: 42.0 %
Coolant temperature: 16 °C
Voltage terminal 30: 13.980 V
Pressure sensor for reducing agent: measured pressure: 0 hPa Sensor for reducing agent fill level: fill level: 0.00 %
Sensor for reducing agent tank temperature: temperature: 7.9 °C Reducing agent pump: activation: 0.00 %
9633 - Reductant Level Sensor
P203A 00 [00100111] - Electrical Malfunction Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1 Mileage: 216271 km Date: 2127.14.31 Time: 17:08:19
Engine RPM: 929.00 /min
Normed load value: 27.8 %
Voltage terminal 30: 14.320 V
5327 - Boost Pressure Control Valve/Solenoid (Bank 1)
P0047 00 [10100111] - Short to GND
MIL ON - Not Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Priority: 2 Fault Frequency: 1 Mileage: 216271 km Date: 2127.14.31 Time: 17:08:19
Normed load value: 29.4 %
Voltage terminal 30: 14.060 V
Charge Pressure Actuator: activation: 87.45 % Charge air pressure actuator: acknowledgment: 3.41 % Turbocharger boost control: offset closed: 0.66 % High press turbocharger actuator: status-Bits 0-7: 0 High press turbocharger actuator: status-Bits 0-7: 8 High press turbocharger actuator: status-Bits 0-7: 55 High press turbocharger actuator: status-Bits 0-7: 68
High press turbocharger actuator: actual uncond volt value: 3196.4 mV Accelerator pedal travel: 0.00 %
9638 - Purge Valve for Reductant
P20A2 00 [00100111] - Short to GND Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1 Mileage: 216271 km Date: 2127.14.31 Time: 17:08:21
Engine RPM: 924.00 /min
Voltage terminal 30: 14.180 V
Readiness: 0 0 0 1 1
MrCypherr
Ontario
Mk6 Wagon
Looks like its a wiring concern just from looking at those faults. They all came on at the same time. Couple of them are short to ground faults and the one for the level sensor says Electrical Malfunction. I would check the wiring to these components, Theres two big connectors at the back where the tank is. Check for power and ground. Seems like your fan modules are affect as well.
JPM
Millington, MI
2013 Passat
They all came on at once because I cleared the codes and this is what came back.
MrCypherr
Ontario
Mk6 Wagon
Maybe check the fuses as well to see if any is blown. Off the top of my head, I dont know whats all on the circuit.
