DPF Pressure Sensors Melted
bigb
Arizona
2015 Sportwagon S
Have not seen that. What kind of driving patterns, mostly short? How many miles on it and do you monitor your regens?
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
Not under warranty? If I was I would try and have them fix everything first then delete if you choose to. Why foot the bill for that stuff? You don't know what all is affected there really. There may be other burned up stuff in that mess.
cpinde
Slower Lower Delaware
05 VW Passat, 04 Jetta, 06 BRM Jetta, sold 15 Golf current
Just shy of 180k miles. Almost all driving is from my commute which is 126 miles each way. My driving would be considered spirited with most drives my car sees 100mph runs. I don't monitor regens but rarely do my regens get interrupted.
cpinde
Technically not under warranty but I'm thinking about taking it to VW and trying to get VW to cover it. Sadly I live about 40 miles from the dealership so I'll have to tow it there, good thing I have a truck and a tow dolly.
740GLE
NH
You sure you don't have a massive exhaust leak at the DPF?
Those pressure sensors are for the exhaust, under normal operation there's no flow as its capped, so no soot, but soon as one end is opened you'll have flow. My guess when the melted, some soot shot past and filled up the heat shield.
ticaf
US Mid-Atlantic
Stock 2015 Golf SW S Manual TDI
I think you are right. The pressure sensor cracked and allow soot through.
Wondering if the failure is due to overpressure caused by a full DPF.
To the OP, what are the codes?
740GLE
NH
I've replaced a failed sensor on my 2010 and it failed signal/electrical wise not port/fitting wise, soon as there is a little crack in that sensor and flow of exhaust gasses happen she'll melt quite quickly.
So it's prob chicken or the egg, did a regen get a bit hot under the collar and melted it or was there a micro crack that finally failed.
How long did the OP drive after a CEL happen?
amontobin
TX
'15 GSW TDI 6MT
This happened to my '15 MK7 MT Wagen after a t-belt change. It was running fine in town but the first time out on the highway (presumably first re-gen) it went into limp mode. I limped to my errand, then had a CEL on the drive home. Code read DPF Sensor Fail. Sure enough- melted sensor.
It's apparently a thing that can happen sometimes after a t-belt change?
Brian's96TDIPASSAT
Connecticut, USA
15 Golf TDI SEL 14 Passat SEL, bought back by VW 11 Golf TDI, bought back by VW 05 Passat TDI 96 Passat TDI, sold
Just happened last week on my 15 Golf after I changed the t-belt and pump. First re-gen about 80 miles later and it smoked it. Got parts/harness repair under VW emission warranty extension so it only cost me a few hours at the dealer
ticaf
US Mid-Atlantic
Makes sense, cracked during timing belt change from moving them around. I assume it was already brittle
Brian's96TDIPASSAT
Connecticut, USA
Never moved them around enough to crack anything. Trust me, just removed the one bolt securing the bracket that holds the assembly. Most of any moving around is not in that area.
740GLE
NH
were you able to just replace the sensor? or the plumbing for the sensor to fix the issue?
RIP TDI
Santa Barbara, CA
If the sensor is that fragile after all those heat cycles, it might make sense to proactively replace it during a TB change. that would at least save having to also replace the harness and it would be one less thing for the dealer to touch.
Brian's96TDIPASSAT
Connecticut, USA
It was fixed by the dealer under the extended policy. The sensor came with both sensors, mount, cover and hoses along with a repair harness that was spliced in.
Brian's96TDIPASSAT
Connecticut, USA
Trying to figure out why it happened. I really don't think it's anything to do with the belt change in regards to the actual physical replacement of the belt. Has to be something with having the battery cables off for a day along with possible changes from a stretched belt to a new belt.
740GLE
NH
a crack/slice in hosing/connections must have happened to allow flow of exhaust gasses through the sensor
pedroYUL
MI, USA
We are talking about what's inside the metallized pouch here, right?
pedroYUL
MI, USA
If yes. That doesn't need disconnecting while a timing belt change, the DEF injector yes like this:
hskrdu
Maryland and New England
The owners in the thread linked by amontobin above from the BRISKODA forum (almost) all report the sensor melting after a TB change, with at least a few confirmations that the mech did not touch the area. Coincidence? Possible....
pedroYUL
MI, USA
Great! Another thing to check and be paranoid about it 🙄 I'll open that pouch later today
Edit: checked and it's all good.
740GLE
NH
my guess is that some shops disconnect the hard pipes the cross the def injector/TB shown in your second picture for ease of access and they don't get seated 100% afterwards.
Brian's96TDIPASSAT
Connecticut, USA
Well I can assure you I did not remove hard pipes, hoses or connectors. You simply have to remove the bolts for hard pipe attached to the upper timing cover.
740GLE
NH
You push the pipes away while doing the timing belt?
Sounds like if you look at those sensors/piping wrong you maybe set up for failure.
demagxc
Massachusetts
2015 Golf TDI SEL
No need to periodically check the sensors. When they go, they go, and you'll know it. Failure triggers a check engine light and when the sensor melts down, the cabin smells like melted plastic and you may see smoke coming from under the hood. At least this was my experience.
pedroYUL
MI, USA
Should they be in a replace schedule (TB schedule sounds reasonable)? I hate to have to splice connectors and such.
pedroYUL
MI, USA
Just finished the timing belt work in my 2015 Passat (CVCA engine), and indeed the plumbing is routed differently than in CRUA. I can see how if you are not gentle here, you could damage one of those sensors.
I had to release both sensors from the bracket, and the one closer to the driver-side I actually had to unplug the hose...both needed to be electrically unplugged too:
pedroYUL
MI, USA
Did my wife's CRUA timing belt last April, and honestly don't recall having to undo those sensors, I never open that pouch... hasn't melted anything yet.
I am 90% sure I cut short a regen right before doing my Passat CVCA timing belt...actually, when I test drove my car right after, the engine stayed at around 1k rpm and later I realized it was finishing that regen interruptus... didn't melt anything...yet.
I'll report here if something does happen.
