Im currently in the same boat. Was there any resolution to this?
Here is the latest auto-scan
# Saturday,08,September,2018,10:11:07:22809
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: 3VWRL7AJ3AM112771 License Plate:
Mileage: 161870km-100581mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: 3VWRL7AJ3AM112771 Mileage: 161870km-100581miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 K HW: 03L 906 022 TS
Component: R4 2.0l TDI G001AG 9983
Revision: 12H03--- Serial number:
Coding: 0050078
Shop #: WSC 08829 002 1048576
VCID: 36632CFC411E64F4CD-8062
1 Fault Found:
006744 - Unknown Error Code
P1A58 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 161873 km
Time Indication: 0
Date: 2013.01.29
Time: 10:04:51
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Pressure: 992.2 mbar
Temperature: 22.5∞C
Mass Air / Rev.: 1100.0 mg/str
Temperature: 47.7∞C
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 052 T HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9037
Revision: 51112 Serial number: 00001002091702
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 2541FBB0ECB81F6C74-8070
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B400C492300FC881202EB921A0042310000
VCID: 7AFBF8CCF586409469-802E
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00148
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 75E1EBF0D4982FEC04-8020
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 2129
Revision: BI111001
Coding: 2D200B3E902F3EE4800800854000000401000086510085605C8020000000
VCID: 377D21F886149DFCD6-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 11031 21 0512
Coding: 009795
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM02EMYD
Coding: 0012340
VCID: 6ED3C49C79CE1C34C5-803A
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME4E4246218
Subsystem 3 - Serial number: 6342MSME4F422753E
Subsystem 4 - Serial number: 6351HSME1F6317112
Subsystem 5 - Serial number: 6361HSME1F4531377
Subsystem 6 - Serial number: 63727SME1F7F137CL
Subsystem 7 - Serial number: 63827SME1F7F000ED
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001831
VCID: 76E3ECFC019E24F40D-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5M0 920 970 G HW: 5M0 920 970 G
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 271D00
Shop #: WSC 00066 123 00148
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 346716F49F6276E4F3-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 270110F2002111
Coding: ED807F07001602001002
VCID: 69D9B7804020FB0C90-803C
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 D HW: 1K5 919 965 D
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1293324T4V1D05
Coding: 0000004
VCID: 3C773ED47F32BEA43B-8068
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADBC88C8D26F01499-803E
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000525088
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 275DF1B85EB40D7C46-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004699681
Coding: 000490
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 31691FE0A87043CC98-8064
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000544298
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 285FF28453AA02044F-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004709723
Coding: 000490
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 534 5314
Revision: -------- Serial number: VWZZZ4H6253873
Coding: 0000040004000A
Shop #: WSC 21862 418 140358
VCID: 46835C3CF1FEF4745D-8012
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 7
Mileage: 161846 km
Time Indication: 0
Date: 2013.01.29
Time: 07:41:56
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
1 Fault Found:
02904 - Hard Warning 3
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 157139 km
Time Indication: 0
Date: 2012.11.28
Time: 21:38:38
Freeze Frame:
Text: 3445723969
Pressure: 1.90 bar
Pressure: 2.40 bar
Temperature: 23.2∞C
Text: 00
Speed: 38.0 km/h
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668150895
Coding: 0A00000000010100
Shop #: WSC 01357 011 00200
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 326B10EC657678D4E1-8066
3 Faults Found:
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 4
Reset counter: 8
Mileage: 161846 km
Date: 2018.09.07
Time: 17:39:11
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 7
Mileage: 161846 km
Date: 2018.09.07
Time: 17:39:11
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 7
Mileage: 161846 km
Date: 2018.09.07
Time: 17:39:11
End-------------------------(Elapsed Time: 02:28)--------------------------
