jesus_man
- Joined
- Nov 9, 2005
- Location
- PNW
- TDI
- 2005 Jetta (gone), 2002 Passat (gone), 2009 JSW (VW bought), 2010 JSW
You are correct. I too did the same thing with fuel conservation, but found that idling killed my mpgs. I do like to allow the fluids to circulate for a min or so before I start driving, especially in below freezing temps. I also installed the Frost Heater with all the goodies to aid in cold starts and make the commute warmer, quicker.
But, as I mentioned before, once the engine up to operating temp, drop it into sport mode and drive a little more aggressively. If they replace parts on your car, you might just make it a practice to drive that way once a week or for 20-30 min a week and if you have a good highway spell, drop it into manual mode and pull it down a gear to maintain higher rpms. If they do NOT replace anything, then I'd start driving it in sport mode for the first week or two. My guess is you won't see a significant hit to your MPG's, but it will be better for your car, especially when it's on you to repair it!
