DPF Light and pulled a NOx Fault - Need Advice ASAP
jesus_man
NorCal
2005 Jetta (gone), 2002 Passat (gone), 2009 JSW (VW bought), 2010 JSW
With my car enduring it's first brutal winter in ND, it seems to not want to operate at 190* anymore. Today, right at freezing, I couldn't get it above 180, even driving in 5th gear at 65mph. So I am concerned that my T-stat isn't doing it's job to allow the condition to be right for a regen. I even have the largest piece of cardboard covering the radiator I could stuff in there.
For most of winter, my car wouldn't come up to operating temps. Even when it was in the 50s and 60s, it might show at operating temps but it would not stay there. I also had the gauge show the coolant at operating temps, but VCDS showed it at 76*C or 168*F, not 190.
ticaf
US Mid-Atlantic
Stock 2015 Golf SW S Manual TDI
It's a bit low, but i would not worry about it if the gauge still shows 190.
My mk7 tdi will do a regen even with a cold engine, it will start like after 5 minutes of runtime. Not sure if the same behavior is expected on the mk6.
You did not answer my answer about proper DPF reset after replacement. Call your dealer and see if they have any clue about having done that.
jesus_man
NorCal
During the winter, the coolant was RARELY at operating temp according to the gauge. My research indicated that the engine needed to be at operating temp as a prerequisite for a regen.
I have no idea if they performed a proper DPF reset. I do know that it's been 30k miles since replacement. Shouldn't I have had an issue prior to this?
Work order says "Replace DPF assembly and EGR filter and rescan DTC no stored at this time"
ticaf
US Mid-Atlantic
My understanding is that the ECU needs to know the current ash level. if the ash level was not reset (DPF reset), then I can see the ECU letting your DPF go near full IF the previous DPF was full of ash. if you have VCDS you can check the ash value. with only 30k it should be low, if you see a high number, then the DPF was not reset and maybe that's [part of] your problem.
jesus_man
NorCal
What levels should I be looking for? I recall looking at it recently, but I didn't know what normal levels were.
ticaf
US Mid-Atlantic
On my mk7, 98% highway driving, I'm filling up the DPF to the rate of 3g of ash per 10000 miles. City driving, and those who love idling, shall expect significantly more.
jesus_man
NorCal
Once I get it back running, I will check the ash level and report back. I am going to be sick if I changed the t-stat for nothing. However, the fact is, it should have been warming up better than it was.
Almagne
Conshohocken, PA
2015 Gray Jetta. 2014 Black Jetta. 2006.5 Gray Jetta--retired.
I'll say a prayer that you can get it all back running, jesus_man.
jesus_man
NorCal
Thanks for the support (and especially the prayers). I know that first weekend I wrenched on it, I was just in a bad funk! I got it back running Friday night and had flushed the coolant system once. Finished the job Saturday afternoon. I was low on coolant and it was a little weak, so I added straight G12 and I need to take it for another spin to mix it all up. I don't think my shop-vac is strong enough to complete this method, but it did help a lot. Also, the cheap vac tube crushed too with the hot coolant, so I will need to replace that.
The engine does seem to come up to temp and stay there, but I haven't driven it anywhere for a real test.
My biggest fights were:
1. Just the lack of space in there. Consider pulling the front end if you attempt this or pack several extra helpings of patience. It can be done without, but being able to have everything right in front of you would make it 10 times easier.
2. I don't recall ever seeing anyone with the bracket that bolts to the side of the block and supports the Throttle Body on the two lower fasteners. This was the cause of my breaking the dip stick tube. Once I removed it, the new tube dropped right in. This gave me a little more room to work in there too. I had removed it once, but put back in there too soon I guess.
I felt good too that once I was done, there were no leftover fasteners!! I use a divided organizer similar to a fishing tackle box to keep the fasteners organized. Each group of fasteners gets it's own bin. Otherwise, I am pretty sure I would forget what went where.
The real test will be a few good commutes and see if I can get the MIL to go away.
While I was waiting for it to warm up, I fired up VCDS.
Oil Ash Volume 18ml
Soot Load Calculated = 12.9g
Mileage since last regen was (shocker!) 220km. So it had ran somewhere in there.
The code still present is P2BA6
yosufp1
Aurora, Ontario
2014 Jetta TDI 6MT
Oil Ash Volume 18ml
I had P2BA6 and P1A58 and it was cleared under emission warranty. Service paper said that the NOx Catalyst was the issue and needed replacing.
jesus_man
NorCal
I have just dealt with the MIL for the last few months as life has just been non-stop. But I had a little time today. Here are my codes again:
011174 - Unknown Error Code
P2BA6 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 252445 km
Time Indication: 0
Date: 2015.10.02
Time: 08:44:19
Freeze Frame:
RPM: 943 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 960.0
Temperature: 7.2°C
Mass Air / Rev.: 340.0 mg/str
Temperature: 18.0°C
006744 - NOx Catalyst
P1A58 - 000 - Regeneration Required - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 11
Reset counter: 255
Mileage: 253482 km
Time Indication: 0
Date: 2015.10.11
Time: 16:52:28
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 960.0
Temperature: 7.2°C
Mass Air / Rev.: 1100.0 mg/str
Temperature: 18.9°C
Readiness: 1 1 0 X 1
So what to do from here? Car has been running great. Getting high 30's for MPG's. But that MIL bugs me.
TurboABA
Kitchener, ON
I see you have a slushbox.... go back on another 30min freeway run and manually shift into a lower gear so that your rpm is above 2k for the whole trip... hold 2.5k even and be patient.... wait until the CEL clears.... it will take about 30 min for the heat to do its job....... alternatively, you could use VCDS to trigger and standing service regen to see if that helps, but I'd leave that option until you've exhausted all others.
TurboABA
Kitchener, ON
OK... I just looked things up to refresh my recollection.....
The regen can take as long as 50min of constant 80-120kph driving.
You can go to Engine\Long Adaptation and either select NOx Regen from the drop down or go to channel 18 and set the value to 1 in order to trigger the regen...... after that, go drive on freeway until the light goes off (so let's say 1hr to be safe)..... do it during off peak hours so that you don't run into traffic or congestion as if you drop below that required speed or shut the engine off, the regen gets cancelled.
cholmes100
Nova Scotia
2012 Passat Highline
It means it has reached a preset amount of failed regens. If you know that it's due to driving habits the system is working properly as it should.
Take it on a drive if the scanner you have can't do a forced standing regen. In the drive you need to go around 2000rpm if the vehicle is upto temp it can be done as little as about 3 miles but may take longer if vehicle feels like it. Make sure you have more than 1/4 tank fuel and pick a road which will allow you a undisturbed drive but no need to overdo do it either (it's OK to slow down if you need to)
Use only low saps oil for exhaust system longevity
That means nothing, my car is all highway miles, no short trips and I still get this code. I believe you will get this no matter what and how you use the car as for most people it will mean a dealer visit and guaranteed revenue stream for said dealer.
TurboABA
Kitchener, ON
Wrong.... they system only "fails" when a part of it is broken.
A properly functioning system doesn't throw this code during the use pattern you describe.
kittykat
San Diego/Phoenix
2014 VW Jetta
I've been having a similar issue. I'm getting a few error codes:
011174 - NOx Emissions Exceeded P2BA6 - 000 - SCR Catalyst Malfunction - MIL ON
006744 - NOx Catalyst P1A58 - 000 - Regeneration Required
006481 - Radiator Fan 2 (V177) P1951 - 000 - Movement Restricted / Jammed
So the problem first began within a few months of purchasing this 2014 Jetta in Feb 2022. The DPF light came on during one of many trips between San Diego and Phoenix. I had no idea what it was at the time, so pulled over to do some research. I wasn't able to clear it that trip, but watched many YT vids and talked to a mechanic at a Phoenix VW dealership and eventually managed to take care of it. That happened a few more times over the next months, but when the Jetta hit about 122,000 miles, just past the 120k warranty limit, the DPF light just stayed on, or went out but came back on. Then the engine light came on too. I was unable to address the situation the same way I had before, just driving in sport mode keeping rpms around 2000-2500.
Back in San Diego, I asked around for someone to pull codes and was able to borrow a VAG-COM cable. The scan showed pretty much the same results I get today (below). The standing regen was unsuccessful. All attempts at a driving forced regen have also been unsuccessful. I thought I had it lat one point last week and then had to return the borrowed cable.
I got the Ross-Tech cable yesterday and tried the forced regen while driving again last night. After over an hour, both dash lights went out and they stayed out longer than an hour for the entire return trip. I was so relieved and proud of myself. However, both the DPF and engine lights came back on when I started the car up again this morning and I am just disappointed and frustrated all over again.
As I was attempting the regen last night, my soot level increased from something like 6 to just over 15 over the entire 2.5 hour drive. They never decreased and I had read that you know when the regen is finished when that soot number gets close to 0. Is that right? (How DO you know when regen is complete???) I read somewhere else that the regen cannot run unless soot levels are over 40, and mine has never come close to that so I'm confused about that.
I was talking to someone at a nearby VW dealership about it yesterday and they again made it sound like it shouldn't be difficult. They told me it would be $380 plus labor, probably 2 hours, more than it was in Phoenix. I bought the cable and converter for about $250 total including 2-day delivery and felt confident that I could do it myself so I tried. So when the lights were on again this morning, I brought her in hoping to just talk with someone and get some guidance but they weren't willing to entertain me. They wouldn't even let me talk to a service manager.
A scheduler said I could leave my car and they'd probably get to it by Tuesday or Wednesday but I'm supposed to be back in Phoenix ar
ound that time and in CO the following week. Besides, that's just to check it out and who knows how long it would take from there. The scheduler seemed to know about DPF issues and said it should be fine for the trip. He told me to just be sure I fill it up with biodiesel as lower quality diesel might be the problem. I'm like how could that be when I fill up at different places between San Diego and Phoenix all the time? I asked how to identify biodiesel and they sent me to 7-11, which has the same damn diesel #2 every other station with diesel has, but for $6.66 a gallon v. the $6.09 at the cheaper gas station in the area.
The scan I ran this morning looks pretty much like the scans from last week. Please help me figure out what I'm missing! Is there something else I need to address first? Here is today's scan:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 47 56 75 77
VIN: 3VWLL7AJXEM423478 Mileage: 198490km-123335miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 M HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H16--- Serial number:
Coding: 0050078
Shop #: WSC 46723 003 1048576
VCID: 382924AEAE5540BB1F3-806C
VINID: 0E69DC70745AA1574408310720045257F5
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 198340 km
Time Indication: 0
Date: 2017.03.05
Time: 11:28:30
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Pressure: 1004.3 mbar
Temperature: 19.8°C
Mass Air / Rev.: 265.0 mg/str
Temperature: 36.9°C
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 7
Reset counter: 255
Mileage: 198340 km
Time Indication: 0
Date: 2017.03.05
Time: 11:28:32
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Temperature: 19.8°C
Mass Air / Rev.: 260.0 mg/str
Temperature: 36.9°C
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 255
Mileage: 198340 km
Time Indication: 0
Date: 2017.03.05
Time: 11:28:48
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Temperature: 36.9°C
Temperature: 87.3°C
Temperature: 19.8°C
Lambda: 9.5 %
Lambda: 0.0 %
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 521 9430
Revision: 05652104 Serial number: 00001312200437
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 1471B01ED27D44DB53B-8040
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C492400FD850F02EB92210042A1100012
Shop #: WSC 02258 002 1048576
VCID: 0451805EAE1DD45BC3B-8050
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BN HW: 5C0 820 047 BN
Component: J301 Klimaanlage 0204
Revision: 2001001S Serial number: 00000002044113
Shop #: WSC 00000 000 00000
VCID: 6D87C5FA919735133C5-8038
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 L HW: 5C0 937 087 A
Component: BCM25 JLB H3 H34 0425
Revision: B2034001 Serial number: 08013065140014
Coding: 7B994B9A08AB0B0008382000240884C50082502E60000000300050002000
Shop #: WSC 28212 003 1048576
VCID: 36352A96A841B6CB0DF-8062
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14202585140213201312
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584140215194400
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH000B1KFH
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Serial number: 0405238 FLE 20140104
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587140211192516
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586140215220302
Coding: 800000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
Component: AirbagVW10 102 0912
Serial number: 003MVD03GY81
Coding: 00004138
Shop #: WSC 00066 790 07030
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 74B1D09EFE3DE4DBF3B-8020
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y1400012MSF0/
Coding: 303036
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME48575D41ZZZ/
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME72621941ZZZQ
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME485E0A2BZZZ0
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME275D0D2BZZZ0
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME3153512AZZZO
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME664C512AZZZ+
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 953 A HW: 5C6 920 953 A
Component: KOMBI H04 0809
Serial number: 00000000000000
Coding: 270A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2B030BE26383FB23621-807E
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H34 0425
Revision: B2034001
Coding: 102200
VCID: 70B9DC8E8AA5D8FB173-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0809
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DCEE6ACF9222B597-803E
Address 2E: Media Player 3
Cannot be reached
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392F21AA955F59B3E0D-806C
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H08 6815
Revision: -------- Serial number: EAA098A0117888
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3_VW36.rod
VCID: 2615FAD67861C64BBDF-8072
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H07 0008
Revision: -----11S Serial number: VWZ4Z7P3544887
Coding: 01020040010006
Shop #: WSC 00066 000 00000
VCID: 2B030BE26303FB23621-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 126
Mileage: 198493 km
Time Indication: 0
Date: 2017.03.05
Time: 19:53:54
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140515
Coding: 02630102C2163A007F1606000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 001010
ROD: EV_OCULow_001_VW32.rod
VCID: 53F373021B7383E30A1-8006
1 Fault Found:
2103041 - Control Module
B1788 F0 [009] - Start Prohibition Deactivated
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 8
Fault Frequency: 1
Reset counter: 126
Mileage: 198493 km
Date: 2022.10.13
Time: 19:53:56
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665617798
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 2E0502F650918E0B45F-807A
End----------(Elapsed Time: 01:45, VBatt start/end: 14.0V/14.1V)-----------
jesus_man
NorCal
It's hit again...seems to be EVERY winter now and this time, quite early. And worse yet, the first time it's cut power!
I think I'm done with it all. Researching what it takes to gut this thing! Any leads would be appreciated!
KKilo
long beach ca
2012 VW Jetta sport wagon
Coding: 0050078
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 198340 km
Time Indication: 0
Date: 2017.03.05
Time: 11:28:30
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Temperature: 19.8°C
Temperature: 36.9°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 255
Mileage: 198340 km
Time Indication: 0
Date: 2017.03.05
Time: 11:28:32
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Temperature: 19.8°C
Temperature: 36.9°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 255
Mileage: 198340 km
Time Indication: 0
Date: 2017.03.05
Time: 11:28:48
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Temperature: 36.9°C
Temperature: 87.3°C
Temperature: 19.8°C
Lambda: 9.5 %
Lambda: 0.0 %
Coding: 0000020
Revision: 00H46001
Coding: 820000
Coding: 820000
Coding: 180000
Coding: 020000
Coding: 800000
Coding: 800000
Coding: 00004138
Coding: 303036
Coding: 270A01
Revision: B2034001
Coding: 102200
Serial number:
Coding: 000000
Cannot be reached
Revision: 00H22000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 126
Mileage: 198493 km
Time Indication: 0
Date: 2017.03.05
Time: 19:53:54
1 Fault Found:
Freeze Frame:
Fault Priority: 8
Fault Frequency: 1
Reset counter: 126
Mileage: 198493 km
Date: 2022.10.13
Time: 19:53:56
ROD: EV_UHVUMI.rod
hello are you able to fix this issue? I purchase my second TDI unfortunately with a tone of issues, I replace timing belt water pump alternator turbo charger, when I replace my turbo DPF filter was cleaned, it runs fine, except this code 011174 - NOx Emissions Exceeded P2BA6 - 000 - SCR Catalyst Malfunction - MIL ON, and this too, 006744 - NOx Catalyst P1A58 - 000 - Regeneration Required, what I found on the fan it was stuck with one of the AC lines check that, you can just shifted with a bar to the side.
jesus_man
NorCal
@KKilo Seems there are some settings within the computer that need reset when you replace the DPF?? Did you do that?
KKilo
long beach ca
No I didn't, my dpf was full of oil from a damage turbo, I replaced and cleaned and put it back on, I only drive it 40 miles after I replaced.
KKilo
long beach ca
I tried to regenerate using vcsd but it keeps given me abort,
Your still have the same issue
jesus_man
NorCal
Yes, I still get the DPF light occasionally. I am trying to drive in sport mode most of the time and limit my idling.
dbbyleo
Colorado
2011 Audi A3 TDI
Just wanted to add my experience with the P1A58 (2011 Audi A3 TDI). After a couple times of being at the dealership for the P1A58 (which I too can't shake forcing a regen with the VCDS)... the last time the dealer had it (back in Jan 2023)... they finally decided they needed to replace the NOx converter (under warranty). I also had them replace the thermostat (out of pocket) since I noticed it was barely allowing the car to reach 87 degrees C. The TDS called this out, but for some reason Audi seemed to have missed it. But based on the TDS, a bad thermostat (ie an engine not hot enough) can create issue for NOx regen.
Anyway... new NOx, new thermostat... 6,000 miles later... P1A58 is back. It seems like this is can be a chronic issue... even after a new NOx.
Would like to know if any of you have finally been able to get it fixed and have it last years thereafter without returning?
I have 3000 miles left on my emissions warranty... and if the prognosis is that I will always be dealing with this... I'll probably just have to sell the car after this last fix. I'd hate to do that. I love the car. If I can hang on to it for another 5 years/100K miles, I'd love to keep it. But all this DPF this and DPF that... makes me think these cars have a finite shelf life regardless of how well you take care of it... and a new DPF and/or NOx would basically "total" the car.
Thought?
jesus_man
NorCal
Driving around in Sport Mode or manual mode a couple times a week, giving the car ample time to warm up first, seemed to help stave off the DPF light. Is that an acceptable solution - I don't really think so. You shouldn't have to drive the car differently to make the regen happen.
Lacking true technical knowledge I surmise that the "tuning fix" VW had to perform is just overwhelming the exhaust scrubbing system which likely wasn't designed for this load. So I fear if left stock, you will always be fighting this issue.
I feel like if you were to weld in a bung upstream of the DPF and be able to spray in some cleaner on occasion, you might be able to keep things cleaned out, but I don't really know how they go about cleaning the DPF while it's in the car.
The other solution many have chosen is to remove that equipment and tune it out of the computer, but I see you are in CO and it's hit or miss if you have emissions regulations where you live or not.
dbbyleo
Colorado
2011 Audi A3 TDI
OK... so based on your response... it seems that a DPF Delete is not an option if you live in a place that requires emissions testing, which I do. Seems to be every two years that my registration renewal will require emissions testing.
jesus_man
NorCal
I can only assume that your TDI would not pass the test, but I could be wrong. Being a CO native, and living in "The Springs" for a spell, I had to have my F-350 tested every two years. It was old enough not to have a DPF, but I will say that I mistakenly left it on a high horsepower tune once and it still passed. I just don't recall what they were measuring for. I feel like it was just an opacity, which means, no rolling coal. But the newer stuff might have to be below certain levels of NOx?? Might be worth looking into. And I think I'd call the dealer and ask them what the long term solution is.
dbbyleo
Colorado
2011 Audi A3 TDI
Update: My car is still at Audi. Latest from Audi is:
They have failed to resolve the P1A58 code with 2 regen attempts. Audi HQ advised them to do it a 3rd time in which it has failed again. I'm told the issue has been "escalated at Audi HQ" as to what the tech should do at this point.
[Recall that they had just replaced the NOx converter 6000 miles ago].
After doing a bunch more research on my own, I have to admit my driving habits likely contributed to this. I've always "babied" my cars - not driving them hard, always looking to extend fuel economy etc; I always let my cars warm up... and because "it seemed like these TDIs took longer to warm up compared to my gas cars" I actually would let it sit idle warming up anywhere from 10-15 min every morning.
I've read since then that both of these habits contribute to soot build-up.
A local diesel shop confirms this. He said it doesn't matter which make, Chevy, Ford, Dodge, VW/Audi... all diesel with emissions controls like these are susceptible to this issue. "They see it all the time" especially with people who buy big diesel trucks "for show only" and never put any real load on it, like towing.
