IV read on some many articles of people having issues with blocked DPF filter, after diy replacement unable to reset engine warning light or reset limp mode.
Well I have the answer!!!
I myself delt with this issue and went to many mechanics who kept telling me the replacement filter is blocked and were not able to force regeneration.
Ok let me break it down, so you DPF filter is blocked and mechanics do a forced regeneration, the engine light comes back on mechanic does regen again after a couple of times the ecu will not allow it again so you replace DPF filter but it's still registering it's blocked the reason is the ecu memory has stored the last reading saying the soot level is to high, you have to do more than just clear the code. With a diagnostic tool you have to tell the ecu that U have replaced the DPF filter them reset the values then clear the codes. And off you go with a healthy exhaust system.
