Originally had this posted in another section, but was recommended to bring it over here. So here it is:
I recently bought a 2009 Q7 TDI. Going through the vehicle and wanting to make sure everything is running as good as can be. I've come across DPF cleaning videos/how-tos, both on and off the vehicle. Seems there's a lot of methods. One of those is using a cleaner you spray directly onto the DPF via a sensor port just upstream from the DPF while in situ. This seems to create a lot of foam and other chemical build-up. Couple questions here:
Is this effective?
Will this harm the SCR or NOx sensor that are downstream of the DPF?
Is this effective?
