Lug_Nut
- Joined
- Jun 20, 1998
- Location
- Sterling, MA. USA
- TDI
- 2015 GSW 6M in S trim the other oil burners: 1967 two stroke Sonett 1988 Bolens DGT1700 1962 Quantum III
My radio has quit. I still have the flashing red anti-theft lamp, fuse 42 is good and the lighter socket is still powered. VCDS does not recognize the radio (controller not present). It does not power up at all to even provide the "safe" code access.
The earlier (A3 /B4) radios had a second fuse on the back of the radio itself and I'd like to pull the radio in this A4 to check if it also has an on-board fuse.
If you're at the fest, and have removal tools that will work on a double DIN sized, non-Monsoon, head unit, I'd like to hear from you.
If you're in the Marriott leave a message in room 507 or you might find me near the blue Jetta pig near the yellow Saab pig in the parking lot.
