I ran across this thread a couple of days ago. It goes into detail about installing a switch inside the door. If you are particular about your car then this may be the way you want to go.
I've decided to go into detail about the way I fixed my switch, yes it seems to be .50 cents more but if you can afford it, this may be the way for you.
I made a trip to Radio Shack and purchased a pack of momentary on/off switches. Part #275-1548. This is a normally closed switch, meaning when the switch is "up" the connection is made. When it is "down" there is no completed circuit.
What you will need:
Momentary On/Off Switch
Ground wire:18 gauge (about 6 six feet)
Electrical Tape
Drill with bit slightly larger than the switch.
1 Self tapping screw.
Wire snake (coat hanger, mechanics wire) for easier wire routing.
No soldering iron is necessary but if you're an overachiever have at it.
Before disassembly eye ball the gap between the door panel and your dash, choose a prime location for your switch, if you aren't making any contact with the door panel your switch is useless, if you make too much contact you can end up with a broken switch or cracked side panel. I found a couple of washers that fit the diameter of the switch to act as shims in case I needed to mount it more toward the inside of the vehicle (in order to make ideal contact). It is always easier to place shims to "shorten" the switch, if you try installing it and find you don't have enough contact you will probably have to relocate your switch.
Disassemble your door panel
Notice the light socket and the two wires running to it. The driver's side ground on my car is brown...ish. Splice your ground wire into this wire, just strip a little back and wrap the stripped end of your ground around it, then tape.
You will be running your ground wire through the hole in the door where the bundle of wires comes through from the interior. (Yellow Circle)
(I took this picture from some other post, the guy was installing door speakers and showed his passenger side. I flipped to image so it all makes sense.)
Pry back the little rubber boot at the door hinge.
Pulling it back is easy with your hands just grab a side and work around it until it lets go. (Note: This picture is taken after the wire has been run through.)
Now run your wire through the hole and pull through.
(Note: At this point I went ahead and tested the ground to ensure the door light worked again...I then reinstalled the door panel to make adjustments to the switch a bit easier for later. (example: eye-balling the gap between the panels, before mounting switch)
Relieve your car of the under-dash panel to gain easier access by removing the torx screws holding it on. (The two directly beside the OBD-II port do not need to be removed.)
I don't have a picture of the panel removed or this next step because I'm writing this after the fact.
Notice where your wires run from the interior of the car and out. it's probably easiest to go from the inside to the rubber boot then pull the wire through.
You will be drilling a hole through the side dash panel in order to install the switch.
I mounted my switch about mid/top of the panel. I also placed a washer on the back side of the panel, this moved the switch inward a little so the door doesn't crush the switch when closed, only making enough contact to disrupt the connection.
Pop the panel off and install your switch.
You will then be connecting two wires to the switch: One coming from the light socket ground wire and the other will be going to bare metal to make the ground. (It doesn't matter where the wires go on the switch, just that they aren't making contact with each other)
I dilled a small hole and wrapped some stripped wire around the end to make my ground. (If you live in an area with high humidity, or if your sunroof drain tubes have failed before allowing water into your vehicle and you find light rusty coat on the metal, you may want to sand the area down where you are mounting the screw for optimal contact.)
Strip the two remaining ends of your wires and connect them to your switch, wrap your tape around making sure no contact is made between the two wires.
Test switch by pressing it down with your finger and watching the light turn on and off.
Reinstall your door panel if you have not done so and under-dash panel. And enjoy your working door.
What you will need:
Electrical Tape
