Got a problem on my right rear door.....will not lock or unlock with door switch or key fob, have to manually lock or unlock it.
Removed the door card and stuck the probes of a 12v test light into the back of the connector plugged into the door regulator on the blue and purple wires which according to the schematics is a direct line to the motor in the door actuator. Fortunately ( or unfortunately ) the light lit for a second when opening or closing the door with the key fob.
Removed the door lock and set it on my work bench and tried applying power from a 12v power supply to the two pins in the connector socket that go to the motor. No worky. Deciding that the only answer was that the motor had failed, out of curiosity, I opened up the electrical side of the door lock and removed the motor and the screw drive mechanism. Now, testing the motor, it worked flawlessly, both directions. Examining the drive, I see chunks of a light orange, plastic, biodegradable type material in it and scattered in the interior of the housing. I clean it up and put it back together and now it is opening and closing without issue!
I'm not sure whether to trust it or not. I tried putting the pieces of the material together and the best I can tell is that it was some kind of bushing but where it went I could not figure out. I have not been able to find out what this is by google or you tube. If anybody else has been down this road before...."enlighten me".
