Sorry i didnt see this response with the Fuse diagram, i will check that fuse this weekend.
in addition i would like to get my CEL off, and it is seeming to be related to either accelerator pedal or that intake flap?
i did pull a VAGCom log, and found a TON of issues. i am not worried about the TPMS, as my new wheels dont have the sensors, and i am familiar with the underseat airbag fix that i need to do. the main thing is i am not seeing that many problems in use, but there are a lot of errors reported. Any added info on any of these, or things to check would be appreciated.
LOG:
Tuesday,11,February,2025,17:33:17:59986
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: 3VWCT71K66M854068 License Plate:
Mileage: 317580km-197335mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65 72
7D
VIN: 3VWCT71K66M854068 Mileage: 317580km-197335miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 1010
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H05--- Serial number: VWZ7Z0F9025705
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 6393A2FD275B1D32229-8036
VINID: 0E69D390705B18674814400620882B2DCF
1 Fault Found:
008214 - Intake Manifold Flap Position Sensor (Bank 1)
P2016 - 000 - Short to Ground
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Mass Air / Rev.: 0.0 mg/str
Duty Cycle: 95.1 %
Bin. Bits: 00000000
Readiness: 1 1 0 0 X
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.clb
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 73B3D2BD97BB8DB2529-8026
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 GS
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 7BA3FA9DBFEBC5F20A9-802E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000000524393
Coding: 14018E234004150007140000001400000028770B5C0000
VCID: 6C81C9C1CA85524A933-8038
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 071206 020 0501
Coding: 00038805
Shop #: WSC 00066
3 Faults Found:
00906 - Horn (H1)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 315657 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.65 V
ON
OFF
OFF
OFF
OFF
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 316117 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
OFF
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 232
Mileage: 315657 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.65 V
ON
OFF
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F0028088
VCID: 2A0D0FD900F18C7A21F-807E
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 156
Mileage: 314551 km
Time Indication: 0
Date: 2000.00.00
Time: 07:51:12
01304 - Radio
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 123
Reset counter: 16
Mileage: 315032 km
Time Indication: 0
Date: 2000.00.00
Time: 17:53:04
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D07676G
Coding: 0013889
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME136C7656H
Subsystem 3 - Serial number: 6342MSME13194A000
Subsystem 4 - Serial number: 6351HSME0B594C26G
Subsystem 5 - Serial number: 6361HSME0B591C27F
Subsystem 6 - Serial number: 63727SME0B2F4B137
Subsystem 7 - Serial number: 63827SME0B2F646DI
2 Faults Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - Intermittent - MIL ON
02512 - Pressure Sensor for Seat Occupied Recognition (G452)
014 - Defective - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0002021
VCID: 015F8875DD07AF22505-8054
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 973 D HW: 1K0 920 973 D
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F9025705
Coding: 0017207
Shop #: WSC 03230 067 57207
VCID: 2E0503C93C19E05AFD7-807A
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 3100106A191336
Coding: 3DBF0B620F001002
VCID: 2C0109C10A05924AD33-8078
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 71
Reset counter: 14
Mileage: 315032 km
Time Indication: 0
Date: 2000.00.00
Time: 15:16:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 316117 km
Time Indication: 0
Date: 2000.00.00
Time: 20:32:27
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T2FYW04
Coding: 0000003
VCID: 392F2095F55737E2585-806C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1610
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 32008001 Serial number: 00000615169020
Coding: 0001205
VCID: 3B233A9DFF6B05F24A9-806E
1 Fault Found:
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 250
Mileage: 316572 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 343111A1D235CA8A8B3-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 02900F880186281B0904058FB0880F0488DC00
VCID: 04518161C215BA0A7B3-8050
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000104676
1 Fault Found:
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit - Intermittent
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Revision: 32008001 Serial number: 00000044569128
Coding: 0001204
VCID: 3C213981FA6502CA433-8068
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: None
Part No SW: 3C0 959 703 C HW: 3C0 959 795 D
Component: J388 TUER-SG HL 1509
Revision: 12008001 Serial number: 00000006594928
Coding: 0041104
Shop #: WSC 12336 024 394758
1 Fault Found:
01044 - Control Module Incorrectly Coded
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 232
Mileage: 253357 km
Time Indication: 0
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0440
Coding: 0100101
2 Faults Found:
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Status: 01110100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 178
Mileage: 315625 km
Time Indication: 0
Date: 2000.00.00
Time: 21:37:01
00625 - Vehicle Speed Signal
Freeze Frame:
Fault Status: 00111000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 0
Mileage: 316725 km
Time Indication: 0
Date: 2000.00.00
Time: 06:47:16
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000866669
Coding: 0001168
VCID: 3FDB4E8DEB7319D2661-806A
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D0704C5311F9B42C4D-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----------(Elapsed Time: 01:33, VBatt start/end: 12.1V/12.1V)-----------
