dae06
I just had a local auto body shop repair all the rust on my car through the VW warranty. When I got my car back (one month later), the dome light would not come on when opening the drivers side door. It does come on for the other doors though. The auto body shop said it is most likely the micro switch on the latch, but because VW says that this is a very common issue, the shop doesn't feel its something they should have to fix it. They contacted VW and the dealership can fix it for $375.00.
Prior to the rust repair, I had no issues with the dome light, however I have had issues with the drivers side window prior to the rust repair and am hoping someone here can tell me if this is switch related also.
When I lift the window up lever, there are 2 stages:
Would it we easier (but more expensive) to replace the whole latch? I'm hoping someone has done this repair on a MKV-A5.
BTW, I had my drivers side door wiring harness replaced 3 months earlier and noticed when I got the car back from the auto body shop, that the rubber boot that attached to the A-pillar of the car was broken. They did fix this since they had taken the doors off, but I'm not quite sure how they did that.?.? It is now tight to the A-pillar again. I'm just hoping they didn't cut any wires by accident.
Any help on repairing the door latch or micro switch on the MKV-A5's is appreciated.
- Half way up I can control when to start and stop the window while going up.
- If I pull it all of the way up for ~1 sec, the window should roll all of the way up by itself. This is the function that I have been having issues with. Sometimes this works and sometimes it doesn't. Could this also be switch related?
