vwtdi04
I am stuck with timing belt, I can't remove the engine mount from the engine side, I lift the engine high enough and I can't get enough clearance to take it out, the A/C pipes are on the way , the instruction doesn't provide much info how to remove it,
is there a trick to it. I can't move much to the side where turbo is located there are pipes ,
any help appreciated
