PITA for sure, but those that are cutting the ring I think you will notice that the mount will slip down and the dog bone will rub on the subframe. I had my subframe out both times I replaced it, first time the ring deformed and broke and I drove around like that for 50k miles. The second time I replaced the mounts it was a lot warmer out. I put the mounts in the freezer and I was able to press them in with no problem the second time and they didn't deform anywhere near what the first set did trying to press them in. I should note that the mounts were different suppliers though. First set was from the dealer, the second set I got was from ID parts.
So you removed the subframe and pressed both the upper and lower in from the top side? Were the top/bottom bolted together when you pressed them in?
I have some questions about dropping the subframe. Since it is just part of the subframe that you are dropping, and you don't have to unbolt any suspension stuff, do you have to worry about an alignment when you bolt it back up? Is there anything you need to support when removing just that piece of the subframe? Is there anything special you need to do to line up the subframe when putting it back? Also, is it best to do it with the front wheels/suspension loaded or unloaded?
I spent hours trying to press the lower mount in through the bottom with the subframe attached. I also went through 2 mounts at $60ea. I gave up and cut the ring, but I don't like the though of the lower mount not being pressed in tightly.
Here is a vid of engine movement during startup with the cut stock lower dogbone mount:
http://www.youtube.com/watch?v=GT3IqwzjR7g
I think I finally found a solution, apparently when you buy a new subframe:
http://keffervwparts.com/parts/2012...teid=216177&vehicleid=1502988&diagram=9274260
(Item #1 in link above)
It comes with a new upper and lower mount installed. So for $380 shipped, I can get a new subframe with the mounts in there, and all I have to do is unbolt the old subframe, and bolt the new one in! Totally worth it to me, to never have to deal with this again!!!
