keaton85
Just get an xtool vag401
Mobile, cheap and runs most of what ross-tech can run.
works for my 2002 vw jetta TDI just cleared a code and read it yesterdayThanks again, but I don't see those settings(or written in that terminology) in the Torque Pro app version that I have (there are settings to getting the adapter to read from the ECU quicker, or slower, but nothing like what you indicated above.
I did give it a go changing these fast/slow adapter settings, with no luck, and my Torque Pro is the latest version.
Maybe it's just the ELM 327 adapter is incompatible with this year of manufacture/model, or type of ECU, I am prepared to buy another Bluetooth adapter, but I'd like to get one that's known to work with this particular VW TDi and it's computer.
I know my existing ELM 327 does work correctly though, and that it does pull up real-time data, and fault codes from the family's other VW cars, and that I don't think there are bent pins or problems with the cars ECU, I'm thinking it's just an incompatibility issue between my ELM 327 and the ECU somehow.
Cheers
