djmeier1
Thanks for the effort, Dabooj. I am presuming that this result will show to the scientists in the group that acetone use represents false hope. Jetta Jake are you out there?? Nick??
You can always use screen capture (ALT-PrintScreen) and then paste that into Irfanview or some other image viewing/editing application. Irfan can convert between bmp/jpg/gif/tif/u-name-it file types and yet another reason Irfan (www.irfanview.com) kicks such total butt is that you can install it at work even on coporate systems where they normally don't let you install anything on their IT-managed, vanilla PCs (no admin access).daBooj said:I don't have pretty pictures, but I don't have a good way to get my results off of the computer yet.
Don't put the nail polish remover in your fuel tank, LOL. I didn't know acetone would mix with water.. Protein huh? I guess that's to keep your fingernails from drying out? The acetone we're using is what you find at most hardware stores in the paint section. I'm not too sure what the exact percentage is for the nail polish remover.. The can of acetone I have doesn't say that it contains anything else, so I'm assuming it's straight acetone, unless someone here knows otherwise..eb2143 said:What percent acetone is your average nail polish remover? The one I found laying around was, "Nail Polish Remover enriched with Protein!!" It seems to have a lot of other stuff in it besides acetone, including water.
djmeier1 said:Thanks for the effort, Dabooj. I am presuming that this result will show to the scientists in the group that acetone use represents false hope. Jetta Jake are you out there?? Nick??
Dave, I was never sure what surface tension would tell us. I'd say it's far from definitive, much like my dyno run. Too early to draw that conclusion. Let's revisit some of Ernie's earlier thoughts from page two of this thread:djmeier1 said:Thanks for the effort, Dabooj. I am presuming that this result will show to the scientists in the group that acetone use represents false hope. Jetta Jake are you out there?? Nick??
Ernie Rogers said:Hi, Nick,
Direct-injection diesels are unique in the kind of two-phase combustion going on. If the burn rate is limited by fuel-air mixing, then fuel breakup and evaporation may not have much effect. But, if droplet evaporation is the limiting process, then factors that affect that will definitely affect the burning rate and combustion efficiency. BOTH low surface tension and presence of a low-b.p. component will promote droplet breakup and consequently the rate of evaporation.
Now, how do you measure "boiling point" for a solution? Help me with the term-- differential thermography? You look for the steps in the curve, each one is a "boiling point."
Now, is this the right thing to measure? Probably not. What would you see if you drop the liquid onto a warm plate? If it foams up at a certain temperature (like soda pop), then I would say droplet breakup would have occurred. What do you think? I'm guessing. Heat and mass transport rates should be looked at to decide if the acetone (or any other light component, for that matter) can "blow apart" a droplet.
nicklockard said:I agree with Dave. Surface tension can not be correlated to fuel economy(edit--to my knowledge.) Surface tension and b.p. depression are useful data to have, but neither can be correlated to fuel economy inside a diesel engine(?) The dyno test (as proposed previously) against a control sample and measuring fuel consumption with a graduated cylinder will be more definitive (elucidate causation rather than correlation.)
I can still try and do b.p. depression. I'll do it after hours in test tubes in a heating block. We're finally settling down here now that the hoods are installed.
My edits in italics.
Ernie Roger's nail polish thread comments said:My wife has a bottle of "average" nail polish remover. The description begins-- "Non-acetone ..."
The ingredients begin-- "Ethyl acetate, alcohol, water, blah, blah, ..."
I think the original, "average" nail polish remover was pure ethyl acetate and that would dry out hands, so they added some junk later. I didn't know they ever put acetone in.
Now, let's ponder this question one more time-- does acetone (or other volatile organic) add anything to mileage, i.e., engine efficiency?
Hmm, does ANY additive work? How about Power Service, does that improve mileage? ---Well, maybe. It contains ethers that raise cetane a lot. So, some additives will raise cetane, and that can improve mileage for an engine that injects fuel a little bit late. We think that biodiesel can improve mileage at low percentages, and I think that may be connected with a faster burn as well as a slight increase in cetane.
Hydrogen gas injected at low percentage into the intake air is reputed to boost mileage, and some people are certain that "humidifying" the air improves mileage.
Most of these benefits are probably real, and they generally add no extra energy. We know that diesel engines have combustion efficiency of about 98% or better, so no chemical additive can improve combustion efficiency enough to notice. The remaining factor is timing.
Remember that increasing injector nozzle size also tends to improve mileage by allowing the burn to complete earlier, with a slight reduction in combustion efficiency. Smaller nozzles improve emissions by increasing combustion efficiency but sometimes hurt mileage.
So, I think that's the tentative answer: If your engine is set to inject a little late, then any fuel additive that shortens ignition delay (raises cetane) or allows combustion to complete earlier will improve your mileage. A timing advance may also improve mileage. Engine experts in the forums could give more info on this topic.
Ernie Rogers
bobgolf2004 said:Here's a link to an interesting (and unbiased) report on acetone:
http://www.kettering.edu/news/archivedDetail.asp?storynum=406
How much Acetone did they add? 10%? or .000000001%? Or both?bobgolf2004 said:Here's a link to an interesting (and unbiased) report on acetone:
roflmao...Powder Hound said:Y'know, JJ, you could have just let this 2 year old topic die a natural death, as it had been on the way to doing.![]()
ya, but it was on my subscribed list and I like kicking sleeping dogsPowder Hound said:Y'know, JJ, you could have just let this 2 year old topic die a natural death, as it had been on the way to doing.![]()
Where's PETA when you need emJettaJake said:ya, but it was on my subscribed list and I like kicking sleeping dogs![]()
lol...JettaJake said:Acetone is now a verbotten topic @TDIClub per BKmetz -- lock it up, BK![]()
