Ernie Rogers
Boiling point of a solution?
Hi, Nick,
Direct-injection diesels are unique in the kind of two-phase combustion going on. If the burn rate is limited by fuel-air mixing, then fuel breakup and evaporation may not have much effect. But, if droplet evaporation is the limiting process, then factors that affect that will definitely affect the burning rate and combustion efficiency. BOTH low surface tension and presence of a low-b.p. component will promote droplet breakup and consequently the rate of evaporation.
Now, how do you measure "boiling point" for a solution? Help me with the term-- differential thermography? You look for the steps in the curve, each one is a "boiling point."
Now, is this the right thing to measure? Probably not. What would you see if you drop the liquid onto a warm plate? If it foams up at a certain temperature (like soda pop), then I would say droplet breakup would have occurred. What do you think? I'm guessing. Heat and mass transport rates should be looked at to decide if the acetone (or any other light component, for that matter) can "blow apart" a droplet.
Ernie Rogers
Hi, Nick,
Ernie Rogers
nicklockard said:I agree with Dave. Surface tension can not be correlated to fuel economy(edit--to my knowledge.) Surface tension and b.p. depression are useful data to have, but neither can be correlated to fuel economy inside a diesel engine(?) The dyno test (as proposed previously) against a control sample and measuring fuel consumption with a graduated cylinder will be more definitive (elucidate causation rather than correlation.)
I can still try and do b.p. depression. I'll do it after hours in test tubes in a heating block. We're finally settling down here now that the hoods are installed.
My edits in italics.
