rackaracka
- Joined
- Nov 15, 2001
- Location
- Monroe, NJ
Or you'll find that the injectors were installed like mine were, with STEEL washers. Thick steel ones - no joke. I retrieved them from the head with a magnet.Once you remove the injectors the copper washers will either be stuck to the bottom of the injector or you will see them on the top of the engine case.
You might also want to change the IQ settings and bump the number a little.
I would actually first see if you cannot get it to smoke less by changing the IQ value through the vag-com, then if needed change the copper washers.
