gmcjetpilot
Do I Need to Re-Align after Changing Struts (and rear shocks)?
Reading the manual there are three adjustments: -Toe; -Camber; -Castor
- Toe is adjustable, with tie rod end. The struts could have changed toe slightly?
There is slight play in the lower ball joint to control arm. There is slight play in
upper strut mount. I used witness marks made by bolts to locate upper strut mount....
- Camber is not adjustable according to manual and says "but can be balanced
side to side by sliding the sub frame left and right." I don't think struts effect this.
- Caster is also not adjustable and no other option available, it is fixed.
Comments? $80 to check tow alignment? Have not driven much since struts installed
today, but it seems to be a delight, tracks straight as it always has. I'll know more
tomorrow when I drive to work.
Related threads:
http://forums.tdiclub.com/showthread.php?t=468457
http://forums.tdiclub.com/showthread.php?t=470098
Related threads:
