eugene89us
Good morning, all,
I was changing the oil on the Passat this weekend, and noticed that Diselgeek's Green serpentine accessory belt has turned black on its back. It caught my eye, since I wondered how it can lose it original green-ness within 10 months/10k miles. The only thing that touches the back of the serpentine belt is the tensioner. I decided against replacing it during TB job, since it still looked pretty good. However, it has plastic parts, such as the roller itself made of plastic and I believe there is some kind of plastic piece in the spring itself. As I am noticing that over last 10 years since the car came off the production line, the plastic components are the weakest link in this entire vehicle. Everything that broke so far, such as valve cover leak, oil cooler leak, a couple of door lock actuators - all kicked the bucket due to plastic becoming brittle.
Looking at the belt, it is moving smoothly with the engine, there is not any wobble or inconsistency with it. So I can't blame the one way clutch of the alternator or the tensioner itself. But of course my worry is that if the plastic tensioner wheel is indeed the weakest link, I would hate to see it fail causing serpentine belt to be swallowed into the timing belt, causing major engine damage. Seeking expert recommendations as to your perceived longevity of the tensioner, and whether it is worthwhile to change it preemptively? Is there a shortcut to replacement, because reading ErWIN manual, you basically have to remove everything in front of the bolt. If that is the only way, I may decide to do both the tensioner as well as replacement of thermostat while I am already there.
Edit: Another thing I considered is buying a tensioner and just replacing the plastic wheel itself primarily to renew the plastic while I am sure the print itself would last until next TB change. But once again, I am not sure of tensioner failure rates and whether I should just leave it alone for another 100k miles.
