Tdimrtwo
I’ve always thought that DPF’s filter out soot (carbon particles), burn them off during regeneration, but inevitably accumulate ash, which can’t be removed during regen , culminating in a clogged DPF that must be replaced, or at least manually cleaned.
But, I recently came across a video from Australian self-proclaimed “Auto expert” John Cadogan stating that a dpf should last indefinitely, and dpf failures are nearly always the result of other problems in the engine. If the DPF is replaced without fixing the root cause, it will soon have to be done again. Any thoughts on this from the TDI community?
I have a 2015 CRUA with 220k that’s showing a CEL and dpf excessive regens message and occasionally a dpf failed alarm on the display. I’d like to fix it right with any underlying cause, if possible.
Here’s a link to the YouTube video:
Comments?
Comments?
