stra0529
Hi all, i just bought my first VW (06 jetta 1.9 TDI w/DSG) a few weeks ago w/114k and have been on this site quite a bit, seems like a great community.
When i bought my car i thought the transmission wasnt as it should be but ive heard DSGs take getting used to. Well i brought it in to the dealer for free inspection and they claim my DMF was failing (did notice the noise after knowing what to listen for even though it wasnt as bad as some here have had and car had slight free rev at lower rpm, also trans leaking. I didnt notice much if any leaking when i took of the bottom skid cover when i changed oil. I figured from reading around that the DMF should get changed out sooner than later so i tackled it yesterday with a DMF i bought from Aaron @ Boraparts.com.
Bad news - it seems worse than it ever has...
At first the car seemed fine pulling it out of the garage but then when i tried to drive away the tranny didnt want to shift smoothly until high revs and between shifting in/out of gears (mainly 2nd and 3rd) there is a grinding/vibrating sound and car doesnt feel like it has much power, keeps cutting out at about 2000rpm like a severe hiccup. At first i thought it was just the ECU relearning as it appeared to get better as i was shifting into sport and tiptronic and back to drive few times and then running good (about 5 miles of driving after fresh DMF replace), still seemed little under powered but didnt want to be pushing so maybe it was just me not givin it gas but was shifting good. Parked for a while and then it started to do the sever hiccup again next time i drove, and is still but it only seems to do it when its coldest (most noticeable even though it seems like its still weaker when warm..taking longer than norm to get up to speed) When it shifts it makes a grinding/vibrating sound like it free revs and grinds then shifts, when shifting in tiptronic it is smooth.
I did loose small amount of tranny fluid (1/6liter) at very very most, tried to remove the 3 bolts that held on the tranny cooler but they were all stripped from a previous job so i attempted to remove one of the hoses pinched but still lost little bit, pluged with finger and replaced hose. Left cooler on when replacing DMF. What i did notice about leaking trans fluid was it looked as though there was little wetness around trans filter housing as maybe bad seal but know i cant check fluid and prob shouldnt replace filter either without changing fluid all together.
Engine light came on but it was just for MAF and since cleared code. I did notice when i took the flywheel out of the packaging (new, LuK oem upgraded DMF) before installing that it had some play in it when rotating it, i would say about an inch but figured that was fine as it was new and threw it in, the one i took out had about half that but figured it was grinding/binding inside?? Reading around after it sounds as though 10mm max play is allowed, maybe the new one was less than an inch but for sure more than 10mm. Do you have any idea what might be my issue, bad new flywheel, loss of tranny fluid, something else??? Any input would be great.
Also i was thinking i should change the trany fluid but need a Vag-com or VCDS to perform, is there anyone that has one that could mail me one and ill mail back or borrow if theres anyone in the area, i live in north branch minnesota and cant afford one as i blew all my spare money on the DMF and wifes pissed i made car worse after spending $$.
Im mechanically inclined for the most part, mech. engineer and always grew up working on motors and small engines but this is way way over my head and am frustrated but open for any ideas..
EDIT: the first time check engine light came on i had it scanned and it read P0101 - Mass air flow vol..., and P0299 - unidentified fuel and air metering error from generic reader. cleared codes and rescanned after wiggling MAF connection and got P0102 for mass or vol airflow circuit low input, cleared all errors and check engine light just came back on after about 3 start-stops totaling about 30 miles. Limp mode??? it seems when i first start it has this shift problem and until i shift into S or tip it will then smooth out shifting but lack of power - limp mode that i hear in some posts???
Any help is greatly appreciated.
Thanks all for reading.
Josh
Josh
