Read all about it....
http://www.dbwllc.net/product/dlc-800-100-130hp-pd-engines/
Flow Data: +42% over Stock Flow (vs the 100hp Bosch DSLA 150P 1362 nozzle)
Supports Power Outputs from: 100-170hp (with supporting modifications)
ULSD Rated Nozzle – 5 year unlimited mileage warranty1
Variable Staged Flow settings; Custom are available at no charge2
Flow Settings:
We suggest using the original flow setting, this is ideal for most applications
Custom Flow settings are available, but are set on a case by case basis.
– All prices include: PD Injector Overhaul with Mounting and Balancing
– Works perfectly with Stock and Tuned Engine Control Computers
– Lower Turbo Inlet Temperatures
– Includes OEM seals
– Greater efficiency due to faster fuel air mixing in the Bowl
– Faster Fuel delivery providing more time to efficiently burn fuel
– DLC (Diamond Like Carbon) Coated needle
– 3-4 fold increase in nozzle life
– Faster cycling low friction needle
– 10%+ greater precision in flow control
– Tighter tolerances, less internal leakage
– Tighter internal tolerances than OEM by up to 50%
– Atomically perfect DLC coated sliding surfaces
– Optimized hole geometry for improved atomization and dispersion
– Hardened wear surfaces
– More power than the OEM parts with less pump displacement volume
– More torque than OEM parts
– Improved economy by up to and in some cases greater than 10%
