y2khardtop
- Joined
- Jul 8, 2006
First of all, I must say how extremely dissapointed I am with German automakers for not find speedo accuracy important. I've been through this on several BMW's, and now our TDI Jetta. Also, if this has already been covered on this site, I apologize.
**Shut everything down and remove the key**
First, you must remove the little cover under the gauge cluster. Just lower the steering wheel, grab it with both hands, and pull it towards you. You will feel like you are breaking it (I did), but it just slides out). It is attached via fabric, so just lay it down on the column..
Now, you must remove the two small torx 20 screws at the base of the gauge cluster. It is easier if you have a torx driver, as there is barely room for a screwdrive with exchangable bits (although it can be done, just tight).
Now, the entire gauge cluster slides straight out. It has an integrated connector in the back, so it can only come straight out. It is a tight fit, but it will slide out.
Now, you must separate the clear plastic cover from the cluster. This is done by depressing the 6 clips, and sliding them apart. On a BMW, this is extrememly hard (usually damage the connectors if you don't have their special tool), but it is easy on the Jetta
Now, all you have to do is rotate the needle on it's shaft a small amount. With the ignition off, the speedo motor locks itself down, so if you apply a force to the needle, it will rotate on the shaft.
I made one adjustment, then put the speedo back into the dash WITHOUT the clear cover. Just slide it straight back in. Then, I hit the road with a portable GPS. First time, I overshot a little, and my speedo was reading a little low. Second adjustment I hit it perfect, and it is within 1/2 mph at 60mph.
Now, you could pull the dash back out to install the plastic cover, but you don't need to. The plastic connectors will lock back into place just by sliding it straight over the dash.
Then put the screws back in (if you drop them, they'll fall through, so all is OK), and pop the little cover back on.
Enjoy!
Enjoy!
