RIP TDI
- Joined
- Feb 16, 2000
- Location
- Santa Barbara, CA
- TDI
- '15 GSW SE 6MT, '01 Golf GLS 5MT, '96 Passat variant
The Problem - Pano roof leaks are pretty common and there are TSBs on repair of cracks in the plastic drain trays in the pano frame and a bad frame-to-body seal due to a poor weld. Service Campaign 60E5 specifies cleaning the front tubes and removing the front tube check valves to prevent the drain backup that can cause front headliner leakage. Hopefully, dealers are also cleaning and removing the rear tube check valves since leakage at the rear headliner is an issue, too (I had leakage at the rear only).
This DIY covers removal of the 4 drain tube check valve caps in a GSW (hatchback procedure may differ). This is a not too difficult first step to solve a leak issue. Further steps, if needed, might be good candidates for the dealer to tackle, particularly removal & repair of the pano frame.
REARS - These are easy to access compared to the fronts. They are located in the far rear corners of the underbody.
1. Driver's side rear is directly accessible. Pull the orange check valve cap off of the black "tail" of the drain tube. You'll find dirt packed behind the cap, so while you're here, run a cleanout line up the drain line to the drain inlet in the pano frame (you won't be able to run the cleanout in the opposite direction). 1/8" bulk speedo cable (available at most auto parts stores) works better than weed wacker line for this purpose. It has better "pushability". Do NOT use air pressure.
2. Passenger's side rear is in the corresponding location to the driver's side and is hidden by this cover panel. Remove panel.
3. Remove the check valve cap and run your cleanout line as before.
FRONTS - A little more work is required to access these. They are located in the plenum well just below the bottom of the A-pillars.
4. Wiper arms must be removed to allow removal of the plenum cover. Put wipers into service position and open hood. Remove the wiper nut trim caps, then nuts. Make a mark indexing the wiper arm mounting hole relative to the spindle splines. Now remove the arms. They will be on there TIGHT! A puller will probably be required. When hand power didn't budge them, I tried a cheap battery cable puller which shattered into pieces without budging them! I resorted to this gear puller, but a quality name-brand battery cable puller is the perfect size and should be more shatter-resistant than my cheap one was.
5. Pull off the plenum weatherstrip, then remove the 3 U-clips (#3 in the illustration) securing the 2-piece plenum cover. Finesse the front outer corner of the passenger side cover out from under the black styrofoam block. Now pull the rear edge of cover out of the windshield surround, pulling perpendicularly to the windshield (see 1st detail inset in the illustration) and remove the cover. Repeat for the driver side cover.
6. Remove the deflector in the plenum passenger side.
7. The passenger side drain tube end check valve cap is now accessible in the cavity below the A-pillar. Remove the check valve cap as before.
Concludes in the following post...
