DIY: DSG Transmission scheduled maintenance (40K miles interval)
skinnyb
Western, NC
2013 JSW TDI
Alright, thanks, that's good to know. I am thinking I may try the Febi Bilstein. Any particular reason why you are planning to switch to OEM?
Mainly because it is available at idparts.com as an option. Their kits used to stock the Febi bilstien but now it is either Liquimoly or OEM. The first kit I ordered from them had 6 liters and you only need 5. I found a vendor to get 4 more to have a whole set for my next change. The Febi bilstien works fine and is reasonable priced. Won't using Liquimoly again, that stuff stinks terrible ugh :(
Marisa05MKIV
TN
05 Jetta Wagon GLS TDI
Maxlife ATF is in no way anything like the VW fluid specified for the DSG.
in fact, if you look at the application chart, it says go to the VW dealer for the VW part number.
https://www.google.com/search?q=G-052-182-A2&ie=utf-8&oe=utf-8
I called Royal Purple today and they confirmed with me that there Max Atf is compatible with the 09A tiptronic transmission and even told me that it would take 2.7 quarts for a drain and re-fill and 7 quarts for a complete flush and re-fill. Also comparing the properties to the valvoline maxlife the Royal Purple had better numbers and it also seems that Royal Purple did more extensive testing according to the available info between the two.(sorry this did'nt format out the way I originally typed it) See comparisons below:
MAXLIFE, ROYAL PURPLE
VISCOSITY:
@ 100c 6.11, 7.5
@ 40c 28.18, 35.0
@-40c 8400, 7150
VISCOSITY INDEX: 173, 180
FLASH POINT: 202c, 226c
POUR POINT: -51c, -69f
SPECIFIC GRAVITY:
@ 60F 0.843, 0.84
FIRE: no info, 475f
How does that compare to the NAPA Altrom febi Bilstein numbers?
Flash point [°C] 200 (EN ISO 2592)
Density [g/ml] 0,85 (DIN 51757) (15°C / 59,0°F)
Viscosity 6,5 mm²/s (DIN 51562) (100°C)
or the Mobil Delvac ATF
Technical details
Viscosity, ASTM D 445
cSt @ 40ºC 39
cSt @ 100ºC 7.3
Brookfield Viscosity, ASTM D 5293
-cP @ -40ºC 8400
Viscosity Index, ASTM D 2270 168
Pour Point, ºC, ASTM D 97 -54
Flash Point, ºC, ASTM D 92 236
Density @15ºC kg/l, ASTM D 4052 0.85
Color Red
Valvoline product support has confirmed their Maxlife ATF is recommended for the Audi/VW 09A, however you can't find a Valvoline shop to change it lol.
When replying, type your text above this line.
The following Incident has been logged with Valvoline Product Support. Please review the information provided, should you need further information or wish to update an open incident, please REPLY to this e-mail or call 1-800-TEAM-VAL.
MaxLife Letter
Thank you,
Ticket Number: 11-511421
Subject: MaxLife ATF
The incident has been recorded as:
Business:
Customer Name: Consumer Consumer
Customer Phone Number:
Incident Description:
Entered on 05/29/2015 at 20:18:02 EDT (GMT-0400) by Daniel Trost:
Customer requesting equivalent to one of the following specifications below. Provided customer information that Valvoline MaxLife ATF is equivalent and recommended product.
Look under Audi/VW:
http://www.valvoline.com/valint/international/english/static_document/MaxLife_ATF_Rev_2013.08.08.pdf
meerschm
Fairfax county VA
The 09A is not a DSG Have you verified it is in your car by looking at the option codes?
(the 02E, however, is a DSG)
this thread is about the DSG.
FXDL
Barrie Ontario Canada
2015 Jetta TDI with DSG
Question. If you only lift the car from the front, will more DSG lube drain out verses lifting all four corners???? I want to get the most out of the DSG as more new in the better!!
Mrrogers1
Omaha NEEEBRASKA
2011 Golf TDI 6MT, 2011 Jetta TDI DSG, 2015 Golf Sportwagen S TDI DSG
Technically, yes, but I wouldn't worry so much about it. You'll have plenty of clean, new oil in here not so sweat the little amount that wouldn't drain. Key is that you have it level for the snorkel to do it's job of properly leveling the fluid amount in the case.
I will consider using Amsoil's DCT for a DGS
I would simply say, it's your $4k error if it causes problem. I'd use the VW/Audi/Febi/Pentosin fluid and not substitute in the DSG. I know Amsoil just rolled out the DCT last year and I suppose, in it's defense, says it meets the OEM spec of TL 521 82, but I think most of us use the VW/Audi//Febi/Pentosin fluids.
waawaaweenie
Central Cal
06 Beetle DSG
I think if you look, the drain plug is in the rear of the case so it really doesn't matter, it will all drain out, just give it some time to do so.
for what the cost is, I would only use time tested lubes in this expensive transmission. I am one to cheap out at times but would kill myself if I destroyed my DSG trying to save a few bucks or being the guinea pig for a new product
Macradiators.com
Romania
2.0 CR 360hp
Motul works nicer than oem one, using it on all my dsg cars, pretty happy with it.
I recommend it!
edge130
northern NJ
Wife's 2009 Jetta TDI sedan (2009 - 2017)
I did my DSG service awhile ago
I bought the all the items from a forum member who worked also at a dealship
The entire kit cost me $125 delivered
All genuine VW parts
No regrets spending that money.
I look at it this way, any job that is labor intensive, I don't want to skimp on parts. I don't want to do that labor intensive job twice.
kraftwerkturbo
Brighton, MI
2005 Golf 1.9 TDI auto
Output test without oil?
Have codes
17130 - Pressure Control Solenoid 1
P0746 - 012 - Implausible Signal or Stuck Off
Changed out 2 suspected solenoids from other tranny. Before filling with $70 worth of oil, can I run the diagnostic test (engine not running I think) with Vagcom (output test)?
DivineChaos
Minnesota
mk6 jetta sportwagen tdi
Have codes
should create your own thread or find one about solenoid replacement. this one is about fluid service. Are you sure the used solenoids were good? I have heard these older dsg's had mechatronics issues. not sire if this is the case here though.
DivineChaos
Minnesota
Have codes
you can also check https://www.ross-tech.com/ and search your code. its a short to ground. Trace the wiring from solenoid 1 to unit and the actual solenoid using DVOM.
Verify chassis ground & to main control unit internally.
http://wiki.ross-tech.com/wiki/index..._(DSG/02E). it seems like wires come off the brain in the trans. so its a bad unit. You can try to fix it yourself as this person did https://forums.ross-tech.com/showth...2e-code-hxu-p0746-please-help&highlight=P0746 see post #9 or replace the unit and have it coded.
Rinderle_77
GJ, CO
2000 Beetle TDI, 2015 Audi Q7 3.0TDI
Well, this thread has removed apprehension about the difficulty of servicing the DSG trans. So, thanks for that.
On the flip side, I was hoping to find some people in here who had really high miles on theirs...that had not had proper service....
See, I purchased an 06 Jetta, that I thought had one of the famous, sealed unit automatics. This car has 215k miles, original owner, who the dealer told that it was an "unserviceable, sealed transmission." Therefore, they drove the car, and kept up on engine oil, oil filter, fuel filter, and air filter changes...as well as all other general maintenance. It does run, drive, shift, etc. just as it should.
The rest of the car is as clean as can be expected for a 215k like car, with immaculate interior, and still has the factory spare and full tool kit.
I'll be ordering the kit in the next few days, and will report back once the service is complete.
OhMT
Oregon
2014 Jetta
Has anyone used an Arduino solution for this in place of Vag-Com. I’m getting ready to do this and $200 to $600 seems like a steep investment to read the temp of the transmission. I’ve already searched the forum.
DivineChaos
Minnesota
If your going to have it awhile. Get one. 230 for a genuine cable is small potatoes. You cannot intend on fixing these cars without vagcom
OhMT
Oregon
2014 Jetta
Thanks for the input from both of you! I will definitely get one, just not right away. I just bought a 2014 Jetta with 70,000 on it, and I’m hoping to join the high mile club. I put 30,000 miles a year on right now so the maintenance intervals are going to come fast.
DivineChaos
Minnesota
I put on 70k miles on my car. 50k just last year. It's so worth it. And cable can always be sold. I'll eventually get the Bluetooth one so I can link with my phone.
