DIY: 2" Lift Kit for Under $40 - EASY!
leevizz6
Bozeman, MT
01 MK4 Jetta TDI
Hey guys, I've had this thread bookmarked for a couple years now and now I finally have the time and space to do this the install photos are gone! I'm sure I'd be able to piece it together but does any body have install photos for a MK4 Jetta? They'd be much appreciated!
dhangejr
PNW is my home
mk4 Jetta
I did not follow this thread to an exact T, but there's two things I'll say.
1) is about the pictures. It's a photobucket thing!
Use either chrome or Firefox in a computer and there's a "photobucket fix" extension that will show the images again. Be patient it works!
2)Facebook and search "lifted water cooled vw" join and enjoy
Baxter'sTDI
Colorado
'02 Jetta
I'm in the same boat. Photobucket fix isn't working on any of the pictures in the original post. The only thing I'm struggling with is the rear shock extensions. Searching around it looks like you can either extend from the top or the bottom of the shock. What's the best option? Any pictures? Thanks!
dhangejr
PNW is my home
mk4 Jetta
Wagon shocks are about an inch longer. They working well for me
I believe what you do is take a 1x1" steel box and put two holes in each side.
One side mates with the car body and gets tightened down.
The bottom side will use a nut and bolt through the shock, inside the box tube is where the nut will be.
I tried shackles , but they need welded or they rub badly. Some have used shock extenders like the link , I believe they had to be re threaded , but in sure somewhere you can get them in correct size. https://www.speedwaymotors.com/Shoc...zrqwDZCvX8e1r-_hk-lIKU9bSPGtGxMxoCZ9IQAvD_BwE
No time for images; but google chrome web browser works for me after I install the extension https://chrome.google.com/webstore/...nk-fix/kegnjbncdcliihbemealioapbifiaedg?hl=en
Baxter'sTDI
Colorado
'02 Jetta
I just can't wrap my head around the idea of using square box to lower the top. If the bolts were perpendicular to the body, sure that makes sense, but they're slanted. I'm sure it would work, my little brain just can't imagine it.
Those extenders though.. I haven't seen them yet. That's very interesting...
Baxter'sTDI
Colorado
'02 Jetta
Hey that link did work! I can see pictures! Looks like what I imagined I guess. Just didn't think it would work very well but who am I to argue with results? Thanks for the help.
dhangejr
PNW is my home
mk4 Jetta
I was not a fan of that idea either. So, I went a different route that others had done.
Truck shackles , and they sucked.
I do plan on drinking a hole in the bottom and bolting and weilding them down...one day. Maybe when I do the rear beam bushings
TDIJetta99
Port Jervis, New York, USA
03... Faster than yours =]
You don't have to touch the shocks to do the rear beam bushings so you may as well just do them now haha
TDIJetta99
dhangejr
I tried replying to your PM but got an error saying you can't receive private messages at this time so here's my reply
I lift the car until the wheels are a few inches off the ground, and support with jack stands usually at the factory jack points where you would use the spare tire jack.
left side brake line you can pull the clip that holds the line to the body and pull the line through just far enough. right side the brake line bracket unbolts from the body with a single 13mm bolt.
Personally I like to unhook the abs harness from the beam axle to avoid stretching the wires. you don't have to unplug from the sensors but there's one small tab that holds the harness about halfway to the sensor.
you'll want to take the parking brake cables off the support tab/wire things under the bushings too.
Put your jack in the center of the beam and put just enough pressure so it won't drop, then pull both long bushing bolts out and lower it down enough to access the bushings. It may be easier for you if the wheels are removed, but it's not necessary.
Then it's pretty much fighting with the bushings the same as you would with the axle out of the car...
hey_allen
Altus, OK
2000 Jetta TDI
The photos are still there if you have the Photobucket hotlink fix addon installed in Chrome, and I believe that there is an equivalent addon for Firefox.
The issue is that Photobucket turned greedy, to the tune of $400/year to host pictures now.
Gear_Head
Texas
So it looks like it’s been about 8 years since this “up-grade” (pun intended!) was put to use and there’s been no new news on its longevity. Anybody have any thing to report?
peteguenther
vermont
2003 Jetta
Lift spacers
Hi i like this low cost lift! What’s the source for the non metal spacers used under the pipe flange?
dhangejr
PNW is my home
mk4 Jetta
Alignment
I’d like to see some alignment spec sheets.
I changed every bushing with exception the the sway bar. Did front subframe when my rack failed. Car is up 2.1 up from 2.3 in rear 2” lift from higher AT tires. Is these tires are brand new , the car has been aligned, the rear camber is off slightly. I anticipated odd rear tire wear, it the front inside tires are wearing very fast, probably 60-75 percent of that tread is gone after 5k miles on a 60k tire!
Anyone else having this? I’m m a post this on the FB page.
vandermic07
West Central Pennsylvania
01 Golf 5 spd, 03 Jetta Wagon
I just redid the whole front end on my 01 a few months back. Front and rear poly bushings, ball joints, struts/springs with 2" lift, poly top strut mount. I had noticeable inner wear in the front within the first 2 weeks (~1000 miles). The car was also really squirrely in turns and rain.
The toe was out by 1" front to back of tire. (i forgot to check after i was done putting everything back together probably because i had just about everything go wrong on this job and i was fed up!! Rust!!). I just used the tape measure method and got her lined up. No more inner wear!! Ive done various levels front end jobs and never had to touch anything.
dhangejr
PNW is my home
mk4 Jetta
I’m having the same inner wear issues.
Did you shift your rear beam at all?
I think maybe m gonna have to pay to gave the subframe and rear beam shifted
jmodge
Greenville, MI
In my case I had to file the ball joint bolt slots very slightly so camber could be brought back in spec.
vandermic07
dhangejr
Ive never shifted a rear beam. only replaced bushings. rears have camber and will wear on the inners from what i have read. Ive never had excessive wear in the rears. i also think that the rear camber is fixed, but i could be wrong.
GEFP
Southern Alberta Canada
2- 2001 Jettas, 2 - 2002 Jettas (1 for parts) 2003 1.8t Jetta (parts) 2014 Jetta
There are shims available from NAPA to bring the rear castor back into specs.
dhangejr
PNW is my home
mk4 Jetta
I’m aware it the shins they were on my plans till I discovered a larger issue.
Boring out the balljoint holes is an excellent idea. I’m going to do this before I take it to get aligned.
I found a shop that says 110$ for an alignment with subframe shift.
jmodge
Greenville, MI
Just to be clear, I’m talking about the holes in the lower control arm. I used a round file and a machinist square on the wheel to bring it to a half degree negative camber. It doesn’t take much metal removal. About ,.030” if I recall correctly
ItAintRodKnock
Fraggle Rock, CO
01GolfTDi
cant find any other information about these... Saw this combo posted in the beef on a budget thread, said to give 3 inch lift. Id like to pair that with Billy HD struts with my Monroe airshocks in the rear to rebuild my current lift.
trying to confirm before i purchase.
It was posted as, jeep JK front springs for our front struts. And Jeep XJ front springs for our rear beam.
What i did come up with is:
Jeep JK- 2007–2018 Jeep Wrangler 2 door
Jeep XJ- 1983-2001 Jeep Cherokee
Part numbers:
JK Front(for VW Fronts)- 52126314AC - $150
XJ Front(for VW Rear) - 52001122 - $96
Summitracing for both, and free shipping looks to be the cheapest I think
Can anyone chime in, would like to get these on order asap if theyre correct.
Sent from my VS987 using Tapatalk
Edit: I guess i was too focused on searching this forum i forgot to checkout google. google does have some results!
on youtube kiddo says he is running TJ springs upfront, and then afew saying JK/XJ as i posted in my questioning.
Im going to checkout the two different front springs closer and pinpoint what is best for me.
