Ramairetransam
Is it possible to disable the autolocking , im having actuator problems and i cant even keep this car from locking . Im so sick of this vw nanny **** . vcds would be the only way , anyone know a workaround.
yes a bandaid that this vw i have is built ****ty and under built and i don't want to replace actuators all the time .It sounds like disabling the auto-lock would be a bandaid on what is a larger problem.
Are you out of warranty already? If not, the dealer will fix.yes a bandaid that this vw i have is built ****ty and under built and i don't want to replace actuators all the time .
got locked in the drivers seats today , took playing with the lock unlock and the rear keeps doing the trying to lock at 10 mph , that's the drivers rear door . so two are f'd up .
So yes id like a bandaid bc of vw.
I tell you if this car wasn't so large and got the mpgs i wouldn't have it .
My bet is that if you have a part number, there are any number of aftermarket sources for that latch and cover.yeah im out of warranty , im at 38000 miles.
